Previous in Forum: Regarding the Power Plant Load Measurement   Next in Forum: 23 MVA Power transformer IR value
ETAP Simulation
03/22/2012 4:11 AM
In ETAP 7.11 UGS Steady State, I received a notification "Steady State temperature calculation diverged". What does this mean? What do I need to do to get results? Do I need to adjust something?
Good Answers: 445
Re: ETAP Simulation
03/22/2012 2:28 PM
More than likely you have provided input data that is inconsistent with the database for the study you are trying to calculate; i.e., you have a 10 MVA transformer where you meant 100 MVA, or a 2 MVA load when you meant 2 KVA. Check your data, then RTFM (Read The Fine Manual) where the error codes are located.
Reply to Forum Thread
