Previous in Forum: Plan Gear and Gear Rim With Inner Tooth in Wind Turbine Yaw System   Next in Forum: Motor Weight Reg
Find Efficiency of Motor
03/23/2012 5:28 AM
Water is pumped out of a well 10m deep by means of a pump rated at 10KW.Find the efficiency of the motor of 4200 kg of water is pumped out every minute.given g=10 m/s squqre
Re: find efficiency of motor
03/23/2012 5:45 AM
Homework?
Re: Find Efficiency of Motor
03/23/2012 10:07 AM
If we know that gn ≈ 9.8 m/s2, why would we use 10?
Oh, the question in your homework is not phrased that way. Never mind.
India - Member - Proud to be INDIAN Engineering Fields - Power Engineering - New Member
04/30/2012 3:11 AM
VTU question???
you need to go, to get something
Register to Reply 3 comments
Doorman (1); PWSlack (1); sharath4 (1)
