Previous in Forum: Find Efficiency of Motor   Next in Forum: Algorithm for Fault Location in 2 Parallel Lines With Different Voltage Level
Motor Weight Reg
03/25/2012 2:21 AM
what should be the weight of motor for 132 kw which is variable frequency drive motor
Re: motor weight reg
03/25/2012 5:03 AM
Rated Speed?
Rated voltage?
IP rating?
Speed Range?
Load profile?
ATEX?
Material?
Imagine trying to answer your own question, then add more information that puts it into context with relevant information.
Otherwise, no-one can sensibly or easily assist - are you comparing VFD rated motor to a standard or what??
03/25/2012 9:04 AM
It should weigh somewhere between what a 100Kw motor and a 150Kw motor weighs, with VFD.
Do you have Google on your planet?
03/25/2012 9:47 AM
There has to be much more to this question than what the OP is providing. What difference does it make how much a motor weighs? Even if this is a motor that will propel a vehicle, the rotational inertia will likely be a bigger complication than the actual gravitational force from the mass of the motor.
Re: Motor Weight Reg
03/27/2012 4:59 AM
Register to Reply 4 comments
Anonymous Poster (1); Florence (1); lyn (1); redfred (1)
