Previous in Forum: cr4 email   Next in Forum: New Form of Energy or Matter?
12 comments
Generation
03/23/2012 4:15 PM
Why is it tha the machine slows down after it has been laoded?
Re: Generation
03/23/2012 4:50 PM
Are you sure only the machine is loaded?
Re: Generation
03/23/2012 5:09 PM
Yes just when it laoded thats when it reduces
Good Answers: 181
Re: Generation
03/23/2012 7:06 PM
Nice try, but you missed the OP's humour by about a Km
Re: Generation
03/23/2012 8:05 PM
1. How fast can you run if carrying 10 kilos of bricks?
2. How fast can you run if carrying 100 kilos of bricks?
3. Hint: torque versus speed performance curve.
Re: Generation
03/23/2012 10:34 PM
See Tornado reply #4.
Re: Generation
03/24/2012 2:26 AM
do you mean a generater driven by an engine? if so, check the fuel flow and the governor.
Re: Generation
03/24/2012 2:57 AM
after it has been loaded
Perhaps you are referring to the moment that a unit is synchronised? then the reason would be because the governor is set to system speed to synchronise, and at system speed when you synchronise the governor is not set for any load, then post #4 above applies.
Regards JD.
India - Member - Proud to be INDIAN Engineering Fields - Power Engineering - New Member
Re: Generation
03/24/2012 6:59 AM
The machine slows down, but it doesn't stops no??? Why do u worry
you need to go, to get something
Good Answers: 16
Re: Generation
03/24/2012 7:32 AM
This can go on and on, but generaly it is one of the below;
A- Overloaded
B- Faulty Speed Governing System
C- Driver faults
Good Answers: 137
Re: Generation
03/24/2012 11:00 AM
It could be perfectly normal. OP doesn't say what the machine is, but for an ordinary electric motor (induction) the speed falls from close to synchronous at no-load, to maybe 97% of that (3% slip) at full load.
Re: Generation
03/24/2012 11:06 AM
The OP doesn't say what or who is loaded either. There's not even a hint how loaded it is. (Well maybe the spelling is a hint.)
Good Answers: 16
Re: Generation
03/24/2012 11:06 AM
Touche.... I don't know why, but I first read it as a generator.
Register to Reply 12 comments
Anonymous Poster (1); Codemaster (1); jdretired (1); lyn (1); Machakube (1); redfred (2); sharath4 (1); Tim in Mexico (2); TonyS (1); Tornado (1)
