Previous in Forum: Method for Analyzing & Detecting Powdered Dried Milk for Adulterants   Next in Forum: Criterion for Defining a Well Mixed Solution of a Liquid In Gas
14 comments
Stainless with Best Balance of Biocompatability, Strength and Corrosion Resistance
03/26/2012 10:48 AM
I want to make a stainless steel piece of jewelry (constant skin contact) that will double as a hex key or maybe a screwdriver. Most jewelry is made with 316L due to it's hypoallergenic properties. I gather this is due to it's low Ni content and also perhaps Cr. However, 316L is too soft to use as a practical tool of any kind. As I see I have 3 concerns with the choice of material:
1. Biocompatability as it will be in contact with skin for long periods of time: we need low nickel & chromium, if we use 316L as a benchmark that means <14% Ni and <18% Cr with low NI/Cr release over time
2. Strength and Hardness as it needs to be used as a tool: guessing but say we need >45 HRC (Hardness Rockwell C) and >100 Ksi (yield strength)
3. Corrosion resistance for obvious reasons: I assume that we need a high level of corrosion resistance when in contact with skin for long durations. Sweat and other skin excretions can be quite corrosive I think.
My supplier wants to use 420 stainless steel and it certainly satisfies the first 2 categories above but not I fear the third.
Research tells me that 420 has a middling grade of corrosion resistance (only in the hardened or hardened and stress relieved conditions). It is martensitic steel, the LEAST corrosion resistant of the 3 classes. It is a very good choice when a compromise between hardness / durability versus corrosion resistance is needed. It can resist corrosion by the atmosphere, fresh water, mine water, steam, carbonic acid, crude oil, gasoline, perspiration, alcohol, ammonia, mercury, sterilizing solutions, soaps and other similar corrosive media. Notably absent from this list is salt water (sweat).
If you look at medical uses of steel you will see that 420 is only used in surgical and dental instruments and not for cardiological and orthopedic uses, i.e. implants. This tells me that 420 is a great material for something that needs to be hard wearing, corrosion resistant and biocompatible while exposed to human tissue but, at least for the last 2 categories, only necessarily for a short time.
Anyway, I am not married to the 420, can anyone recommend a readily available steel that satisfies all three of these requirements, preferably not a custom blend from a single supplier?
Re: Stainless with Best Balance of Biocompatability, Strength and Corrosion Resistance
03/26/2012 4:29 PM
Huh? Notably present in the list was perspiration.
03/26/2012 9:02 PM
Hah!! Guess I skimmed over that! Mea culpa.
SO can we assume that this means contact with skin for long periods of time is fine? Why is 420 never (that I can find) used in jewelry, watches etc. Are there large enough variances in 420 alloys (while still being a 420 alloy) that one supplier's 420 could fail miserably in this application?
In short would 420 stainless be your recommendation or is there another widely available stainless that would be better suited?
03/26/2012 10:08 PM
I don't think you can get there from here.
420 is iffy, Niobium and Titanium are good for implants but may not be strong/inexpensive enough for tools.
I'd try 316L and see what you get. Do you want jewelry, or tools?
Have you considered Hastelloy C-276? It ain't cheap, for sure.
03/26/2012 10:49 PM
316L is not strong enough (<35HRC and <100ksi). Niobium, Titanium and C-276 are all too expensive.
Am thinking 431 as it is the most CRES of it's class (martensitic) however because of its high yield strength, this grade is not readily cold worked and is therefore not recommended for use in operations such as cold heading, bending, deep drawing or spinning. We do need to bend a part 180 deg (around a rad of 3-4mm) so that is a concern. It's a strip of metal about 1cm in width and 1mm thick that we bend using a mold on a stamping machine - do you know if that will be a problem?
03/26/2012 10:58 PM
That's way over my competence level. My experience is in chemical etching equipment, not processing the metals. I think you know more about this than I do.
Milo, our resident metallurgical expert will know.
03/29/2012 4:15 AM
OK but thx for your input anyway (and I'm sure you're being too modest)
03/26/2012 11:45 PM
done some reading on C-276, it has 55% Ni which (based on % content alone) puts it waaaay out of the hypoallergenic field
03/27/2012 3:49 AM
Try looking at the 17 series SS (17-4 low Ni 4.5%.) You can play with the hardening temps to achive a balance of Yield/Tensiel strength to hardness. Corrosion resistance in the hard condition is better that 400 seires comparable to 304
03/29/2012 4:15 AM
thank you, will do
03/27/2012 9:43 AM
"I want to make a stainless steel piece of jewelry (constant skin contact) that will double as a hex key or maybe a screwdriver."
I don't know about anyone else, but I sure would like to see some pics of these.
03/27/2012 10:58 AM
I'm forever misplacing my lug wrench.
Maybe a pendant on a chain would work for me. I don't think my ear lobes (or any other body part) are strong enough.
03/29/2012 4:18 AM
they're actually for quite a well known client, so while I can't show you the designs for obvious reasons am sure you'll be seeing or hearing of them soon.
Location: North of Newport, South of Sunset, upon the great Pacific.
03/27/2012 9:48 AM
I agree with oak50, 17-4PH would be a superior choice is this application. It is readily available (here in the US) in different hardened and annealed conditions.
If you are going to be making hex keys from it you would probably check with a local mill and see if they could provide the hex stock on size, preferably ground, and soft for bending. Once bent and made into parts have them electro polished for maximum corrosion resistance.
Good Luck
03/29/2012 5:14 AM
Thanks so much
Register to Reply 14 comments
Doorman (1); JerMo (1); lyn (3); oak51 (1); robnot (7); Tornado (1)
