Previous in Forum: Method of Connecting Foam Sheets   Next in Forum: Machine Drive Chain
10 comments
Hydrogen Testing
03/29/2012 11:05 AM
If there is leakage in hydrogen pipe line how can we arrest it?
Re: hydrogen testing
03/29/2012 11:11 AM
Find the source of the leak and rectify the problem that is causing it.
03/29/2012 11:12 AM
A pipe made of hydrogen cannot be made for unleakage. Thus no arrest is possible.
What does this question have to do with hydrogen testing?
03/29/2012 11:14 AM
Close the valve. You did install a valve?
Next you determine if the pipe should be replaced, sleeved, welded, soldered or patched depending on the pressure and environment of the pipe.
Good Answers: 18
03/29/2012 11:31 AM
Hi himanshu,
Remember the Hindenburg airship, Hydrogen is a dangerous gas.
Be very careful,
John
Best advice I can give as you get older "Never miss an opportunity to relieve yourself"
03/29/2012 11:42 AM
DO NOT TRY TO FIX IT YOURSELF!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
HIRE A COMPETENT PIPELINE REPAIR COMPANY THAT IS CERTIFIED TO REPAIR FLAMMABLE GAS AND LIQUID PIPELINES.
The life you save by doing this may be your own.
Re: Hydrogen Testing
03/30/2012 2:50 PM
1st get a big torch, no, no, no!!! How much leakage? With hydrogen, hydrogen can migrate through whatever material your pipe is made of.
Good Answers: 34
04/02/2012 6:22 AM
The explosion probably caused the leak has sealed
Good Answers: 67
04/03/2012 1:40 AM
How much leak? Where is the leak, weld leak or flange or thread joint leak or parent metal leak or valve leak? Answer will depend on above information.
In any case repair area shall be purged with air or nitrogen before rectification work because hydrogen is extremely dangerous gas.
04/18/2012 6:57 AM
details : thread or valve,high pressur or low pressure line,pipe material (type of ss316-ss304).....etc
04/18/2012 8:34 AM
Welcome to the asylum. A very good collection of questions. You'll go insane here if you wait for detailed answers to your question though.
Register to Reply 10 comments
Anonymous Poster (1); Doorman (1); jesw55 (1); lyn (1); moamen84 (1); pritam (1); PWSlack (1); redfred (2); Whitephone (1)
