Previous in Forum: 225 A. Linclon A.C. Welder... ( Buzz Box)   Next in Forum: Selection of a Distribution Transformer
11 comments
TPN BUS BAR
03/30/2012 2:44 AM
Dear sir,
Is there 1000A tpn..?
i have a load current of 400A.
Re: TPN BUS BAR
03/30/2012 3:09 AM
Yes.
Re: TPN BUS BAR
03/30/2012 4:29 AM
can u send the iso standard ratings of TPN...
Re: TPN BUS BAR
03/30/2012 5:56 AM
What's the application? Ratings are based on application...
Re: TPN BUS BAR
03/30/2012 6:41 AM
I'm estimating new tpn in my plant... ranges like 200A,300A,500A, like that some standard ratings.. can send that... i have a different loads.. i have apply for that...
Re: TPN BUS BAR
03/30/2012 3:22 AM
What's a tpn?
Re: TPN BUS BAR
03/30/2012 4:26 AM
TPN-Triple pole+neutral
Re: TPN BUS BAR
03/30/2012 4:30 AM
India - Member - New Member
Good Answers: 164
Re: TPN BUS BAR
03/30/2012 5:07 AM
Do you need only the busbar? Or also supports, enclosure, fishplates.....? Don't you need switchgear?And, why do you need a 1000A system when your load is only 400A?
Busbars (and most other stuff) are available in Renard #10 series of preferred numbers.
Re: TPN BUS BAR
03/30/2012 6:44 AM
thanks... ya i have a load of 560A.. i need a switch gear also with supports
Good Answers: 164
Re: TPN BUS BAR
03/30/2012 7:45 AM
Do you mean a Distribution Board (DB) something like this one ?
It has a 3P MCCB as an incomer, with a separate neutral bar. Individual single-pole or three-pole MCBs/MCCBs are plugged in. Many manufacturers are available.
You need only 600A. 1000A is overkill.
Re: TPN BUS BAR
03/30/2012 9:58 AM
Your load current is 400A only. You can use 650 Amp MCCB or 800 MCCB. Basicially for the neutral, we always use neutral link with a copper bar. Not necessary to put up a TPN as the cost is very expensive. You needmore space for the TPN.
Register to Reply 11 comments
Anonymous Poster (2); kvsridhar (2); Simon Wan (1); SolarEagle (2); V S Reddy (4)
