Previous in Forum: MCB, MPCB (Panel Design)   Next in Forum: Medium Voltage (3.3 kV) Pump Motors
IM & PM Used with PLC
04/02/2012 2:54 AM
Will anyone explain me about IM(Interface Module),PM(Power Module) used with PLC please also explain when should be IM & PM are need to be used with PLC? and when not need to be use?
Re: PLC
04/02/2012 3:24 AM
How about using the telephone to talk to the PLC manufacturer's technical helpline directly?
Re: PLC
04/02/2012 4:43 AM
These modules are place in Rack
Power module :Power supply unit for the PLC
Interface module
Interface module: This is a part of I/O modules allows you to control field instruments .The link between the interface module and PLC is controller specific .
See :http://en.wikipedia.org/wiki/Programmable_logic_controller
Correct me if i am WRONG
Re: IM & PM Used with PLC
04/02/2012 1:18 PM
READ THIS FIRST!!!How to Search the Internet It will make your life easier and free the forum of noise.
You only need to use both if you want the system to function.
PLC Manual | Basic Guide to PLCs
Register to Reply 3 comments
lyn (1); PWSlack (1); sriram1988 (1)
