Previous in Forum: Pectin Extraction   Next in Forum: Form-Fill-Seal Machine
Confirming Air Volume Capabilities of a Drying Machine
04/02/2012 4:32 PM
I'm purchasing (4) drying machines in support of a shoe manufacturing process. They are currently being shipped from Italy. As specified by the drying machine manufacturer, each unit exhausts 3.5 m3 of air per second. I've converted this to 7,413 cfm X 4 machines = 29,652 cfm of total air volume being exhausted to the outside. Adding this total to our existing sources of outside ventilation brings the total to about 40,000 cfm of outside air needed to maintain a neutral building pressure. Our current systems cannot heat that much outside air during the winter periods.
I have questioned the accuracy of the air volume spec. of 3.5 m3 per sec. The manufacturer is Italian and I'm concerned something may be getting lost in the translation. The power consumption of the dryer is 8.5 amps at 220V - 3 phase. The exhaust outlet for the machine is 4.5" in diameter.
Is it possible that a motor of that size could push 7,413 cfm of air through a 4.5" opening and continue another 20' before it is exhausted to the outside?
Re: Confirming Air Volume Capabilities of a Drying Machine
04/02/2012 4:38 PM
He he sort of like a rocket engine exhaust...probably more like 741.3cfm...
04/02/2012 6:08 PM
Something's not right.
Model number and manufacturer please.
04/03/2012 10:09 AM
Model # 421 PS
The manufacturer is Elettrotecnica B.C. S.p.a., 27029 Vigevano (Italia).
The manufacturer has offered an additional statement, saying; "the machine only exhausts 50% of the air that it is moving at any given time."
This statement now brings into question their specification of 3.5 m3 per sec. of air being exhausted. It sounds like they are saying the machine exhausts 3.5 m3 per sec. but only 50% of the air is "actually" exhausted.
My goal in posting the question originally was to confirm the validity of 7,413 cfm of air being exhausted through a 4.5" opening. Furthermore, that a motor drawing only 8.5 amps at 220V - 3 phase is doing the job. These numbers do not seem realistic.
04/03/2012 10:56 AM
This being an international forum, I expect someone here can help you with a translation, or technical insight.
04/03/2012 12:13 PM
Thanks SolarEagle,
For clarification, the air consumption provides the forward movement of the conveyor and has nothing to do with the ventilation.
04/05/2012 8:37 AM
Makes sense since 6L/min = 0.0001 m3/sec. So where did the 3.5 m3/sec spec come from?
A quick calculation of Q = A*V and therefore V = Q/A for a 4.5" opening gives a velocity of around 67,000 ft/min. I'm sure the fan is not sized to give that kind of velocity!
Something is off somewhere.
04/05/2012 4:35 PM
The 3.5 m3/sec. is the specification from the manufacturer for the amount of air being exhausted from the dryer (= Flow = Q). Here's what I get for velocity;
Q = 123.6 ft3/sec.
A = .110 ft2 = area of the 4.5" orifice
V = 1,123.6 ft./sec.
Register to Reply 7 comments
Bro Motion (3); lyn (2); pdef (1); SolarEagle (1)
