Previous in Forum: SF 3 X 5F CROSS BAR COOLER   Next in Forum: Pressure Boosting Problems
Thermal Power Plant-Doubt
04/02/2012 11:45 PM
Dear all,
Normally in main stop valves and RSV valves there is one capillary line called leak off line, i.e. a quantum of steam is leaked from the valve and enter into the GSC (Gland Steam Condenser).
Can anybody point the reason of it.?
Thanks in advance
Re: Thermal Power plant-Doubt
04/03/2012 12:07 AM
Reheat steam valves are to protect turbine from overspeed, it is a safety control device....
04/06/2012 8:50 AM
The line that you refer to is usually a bleed off line for a balanced valve. Look the drawing over and see if the valve evacuates a cylinder shaped area. You may also see piston rings.
If you fail to follow through, you will fail.
Register to Reply 2 comments
