Previous in Forum: Wire Color Code   Next in Forum: How to Calculate Demand from Apparent Power
9 comments
Mono-Pole / ?Pole-Less? E¯ Motors/Generators
04/07/2012 7:36 AM
donno for a generator but i can imagine a single magnetic pole (at work) DC e¯ motor
vec(F.res{vec.syntax:^,v,<,>})
vec(I{vec.syntax:•,x})
v(•)(S(N)S)(x)^ , the gener thus should be : F ^(•)(S(N)S)(x)v
? why i haven't heard / read about those things
? must the dI OR/AND dF be non-zero for such to function
> such seems to be "**frictionless" and Hi-(rotation)Speed design
> that likely can be positioned by vec(B) vec(H) // to retrieve **
Whats the issue ((i can seek it from www / p-lib - then it'd B a private research)) , so ...
ci139
Re: Mono-Pole / ?Pole-Less? E¯ Motors/Generators
04/07/2012 8:01 AM
No offense, but even light from a laser with misaligned mirrors is more coherent than your discussion.
04/07/2012 8:12 AM
your fast -- i just reached that my "auto balance bit was set"
so here the right v. ::
v(x)(S(N)S)(x)^ , the gener thus should be : F ^(x)(S(N)S)(x)v
& Dear Forum Member , point out the ... thing you can't comprehend ... so "we" can clearify ... everyone's tired (to ? follow ? alien (not their customary) logic)
ci139
Good Answers: 181
04/07/2012 9:36 AM
Well it's no more incoherent that some of his other posts.
04/07/2012 11:52 AM
so now i get it -- its not the engineering forum but -- more like a Ms. World competition -- Hwo makes more ?? beautiful posts -- sorry i asked it's all one waste of time to confirm you do need to do everything yourself ... haa haa haa (Broadcasters)
ci139
New Zealand - Member - Kiwi
Good Answers: 29
04/07/2012 4:23 PM
Your post makes not a lot of sense to me either.
The quality of the responses to your (all-but totally incomprehensible) OP will, as always, reflect the quality of your post.
I suggest that you re-post your question, but this time instead of posting gibberish, you concentrate on using propoer english words in properly-formed sentences.
paulusgnome
India - Member - New Member
Good Answers: 164
04/07/2012 9:59 PM
OK, i dug up old annals of GE and found the answer you are looking for...
Good Answers: 119
04/08/2012 10:57 AM
You are obviously far too advanced for me to understand your cryptic post. Unless you are referring to some simple devices like a
Faraday Disc
or a
Flux compression generator
further attempts at communication are likely to be futile. Good luck!
04/11/2012 3:21 AM
http://en.wikipedia.org/wiki/Homopolar_generators : "They are unusual in that they can source tremendous electric current, some more than a million amperes" (? pocket welding machine)
((↑ ← this is actually what i wanted to say - design's abit different - but the working principle matches))
http://en.wikipedia.org/wiki/Flux_compression_generator : They also can be used to accelerate objects to extreme velocities, and compress objects to very high pressures and densities; this gives them a role as a physics research tool.
((↑ ← "Never heard of it" -- the Attack of the Clones))
ci139
04/09/2012 7:50 AM
Well, the reason you might not have heard/read about these things is that they don't make sense.
Good moaning!
Register to Reply 9 comments
ci139 (3); Crabtree (1); kvsridhar (1); mjb1962853 (1); Paulusgnome (1); TonyS (1); Usbport (1)
