Previous in Forum: Weld With A420 Elbow to A 106 Pipes   Next in Forum: Compressed air Receiver Design
ID Fan Speed Calculations From ESP to FFP
04/10/2012 5:38 AM
Hi There,
Is there anyone with ID fan calculations when converting Electrostatic Presipitators(ESP) to Fabric Filter Plant (FFP)?
Would appreciate your assistance.
Kind regards,
Good Answers: 445
Re: ID Fan Speed Calculations From ESP to FFP
04/11/2012 10:41 PM
I assume that you are considering replacing your ESP with an FFP to save on maintenance costs; however, they are not generally swap-out swap-in replacements for each other unless specifically designed to be so due to pressure drop and mass flow rate considerations. Contact the manufacturers of the boiler, ID fan and FFP as a start since each case is different.
