Previous in Forum: Hydrogen Gas Expelled When Exposed to Metal(s)   Next in Forum: Determining TSS of Waste Water
24 comments
NH3 Blends
04/13/2012 10:13 AM
Hi All,
It is that time of year again. And our Balloon group is seeing all those NH3 tanks all around us again, yet forbidden to use any. There was a great and lengthy discussion last year, maybe re read some of it to refresh your minds.
http://cr4.globalspec.com/thread/67214#newcomments
Okay,
I'm not a chemist, so here is a question. If you refreshed your mind of this topic by reading up on last years discussion, I have a question.
First if you go to Wikipedia and look at the various lifting gases, many are listed and to my surprise actually water vapor is a pretty good lifting gas.
The idea of using steam (the vapor phase of H2O, i.e. water) as lift gas for a powered airship has been suggested many times. Cayley (1815) was the first, and further proposals have been made by Erdmann (1909), Papst (1969), and Giraud (1991). These projects appear to have remained merely theoretical, although several were quite detailed. It appears that no full-scale trials, or even experiments, have ever been performed.
In the past, hydrogen, helium, methane, ammonia, and hot air have been used as lift gas.
Hydrogen offers the best lifting performance of 11.19 N/m3 in the ISA (International Standard Atmosphere), but its high flammability makes hydrogen politically unacceptable nowadays.
Helium provides 10.36 N/m3 lift and is completely safe, but it is very costly, and is difficult to transport and supply.
Methane provides only 5.39 N/m3 lift and has no particular merit because it offers no safety advantages over hydrogen.
Ammonia provides 4.97 N/m3 lift and is cheap, non-explosive, and quite easy to transport and supply, but it is somewhat corrosive, toxic and malodorous, and has not found favor in practice. Plus because of the meth aspect getting small amounts is nearly impossible.
Hot air must be kept hot by burning fuel, and buoyancy control can be performed by varying the fuel burning rate. Hot air is very cheap and easy to supply, and is completely safe, but it provides rather poor lift. In practice the temperature of the air in a hot-air balloon envelope varies between 100oC and 120oC, and thus the lift provided is between 2.7 N/m3 and 3.2 N/m3. For a powered airship, a disadvantage to hot air is that it is very difficult to pressurize the envelope.
Steam as lift gas has the following characteristics.
First, to remain gaseous at sea level pressure, steam must be maintained at a minimum temperature of 373oK, i.e. 100oC. Because the molecular weight of H2O is 18 while the average molecular weight of air is about 29, and taking temperature into account, the lift provided in the ISA by steam lift gas is 6.26 N/m3. As seen from the Table, this is about 60% of the lift of helium and more than twice the lift of hot air. Steam is non-corrosive, non-poisonous, cheap, and odor-free. It cannot ignite and can be easily produced anywhere.
But the main problem is almost as fast as the water vapor is created, and put into a balloon, because of the cooler temperature, it quickly condenses back into liquid water.
Where NH3 of course will not because of it's boiling point being like -32 deg C.
But obtaining NH3 is well,, well it's probably easier to buy a kilo of cocaine, than it is to buy a gallon of NH3.
OK Blends, Water/NH3 mixtures. Like say even the stuff you can buy at the store. It is a mix of H2O and NH3, at varying percentages.
How does that work out chemically?
If water is 1 H2 atom and 2 O2 atom and NH3 is 1Nitrogen and 3 H2 atoms.
If it is in the bottle a blend of 25% NH3 and 75% H2O how does that work?
Are they still seperate compounds? or what's happening.
OK, thinking further here. Ok if you add heat to water and cause it to turn into gas (It boils) and put it into the balloon as soon s it gets in there more or less because it's cold it condenses out back into water.
and NH3 since it is already above it's boiling point, (-32) it if inserted into the balloon remains a gas until it gets below -32 .
Now the question is,, take that 75% H2O and 25% NH3 and boil the heck out of it to cause all of it to become the gaeous form and in the balloon.
now of course the balloon is cool, so the H2O should condence out yes? but the NH3 should not because it isn't -32 C yes?
And then once all of the NH3 H2O is boiled into the balloon, just wait a while for the H2O to condense down and simply drain it out of the balloon to get a more pure mix of NH3.
Yes?
Like i said I'm not a chemist and I don't play one on TV. so not a clue as to if this is what would happen.
Joe
Re: NH3 Blends
04/13/2012 1:18 PM
How do we know you're not looking to supply a meth lab with cheap NH3 ?
Re: NH3 Blends
04/13/2012 1:53 PM
You don't.
But thats why I gave the detailed discussion about who we are and why we are trying to do this, and our history. If we were really trying to do what you say, would it be smart to have half the message be just about that very thing.?
Joe
Good Answers: 299
Re: NH3 Blends
04/13/2012 4:50 PM
I don't know....
I look at your old posts and read the OP here, I jump to a meth lab conclusion.
Hey, are you that guy from Breaking Bad?
NH3 as a lifting gas? Been done before.
Re: NH3 Blends
04/13/2012 4:59 PM
I know it has been used as an lifting gas before.
zeech!
Thats why I want to use some because it is the one and ONLY!!!! lighter than air gas that has that boiling temp in range of where we need it to be to cause the balloon to rise but then eventually stay floating at a certain altitude.
You siuggest any other gas that can do this and I will gladly use it. but there is none
Popular Science - Weaponology - New Member Canada - Member -
Location: In the sticks of the Central Kootenays, BC, Canada
Re: NH3 Blends
04/14/2012 1:01 AM
Isn't liquid ammonia available by the tanker load on the Canadian praries? I thought they used it as fertilizer. Surely you could find a sympathetic farmer who would sell you a bit.
J.
Re: NH3 Blends
04/14/2012 9:35 AM
It is here also in the USA, If I were to go out and count them in a 1 mile radius of here I bet there are probably 20 1000 gallon tankers out in the fields.
But because of the meth industry all the farmers are too scared to let any go. And the dealers (pun intended) won't sell small amounts.
The meth industry has gotten sooo bad, that the tanks all have locks on them now, and some even have motion sensing cameras on them to record anyone that is even near them!
I mean it's crazy, The Farmer pays ohh average right now $1.40 a gallon, But in chasing this stuff down,, single gallon in the meth lab black market can get ya $5,000
It was in the news a few years ago, that someone actually hooked p to one of the 1000 gallon tankers and drove off.
He was caught and ple dealed out the lab. He said the lab said if he can get him a full tank he'd get $500,000 dollars.
Soit's really crazy out there right now.
Re: NH3 Blends
04/14/2012 6:36 PM
Have you worked out the volume of liquid ammonia you would need to fill a ballon? I would suspect you would be using most of a 1000 gallon tank.
For testing purposes, you need to get your hands on a small tank. There should not be a problem to establish your credentials, especially if you are associated with a bona fide club or society who are an identifiable group. The suppliers might be interested if their higher ups knew that someone was interested in the use of the gas for lifting purposes...ie, the potential for a new market.
You will need to closely establish the chemical resistance of the gas bag against NH3. Also things like the ropes and straps that are attached to the gas bag!
Would you vary the buoyancy of the gas bag by using a small pump to pull gas out of the bag and re-liquify it?
Sounds like a fun research project.
Jon
Re: NH3 Blends
04/14/2012 7:28 PM
Hi Jon
Actually, I will need very little. NH3 has a vol/vol ratio of 947, and for this test all I need is 17 cuft of gas.
so liquid is very little.
Re: NH3 Blends
04/14/2012 4:01 AM
You need that gas they use in Government Speeches! All you have to do is ram a few politicians in a bottle and you've got all the hot air you need to raise a fleet (or floatilla) of balloons!
Re: NH3 Blends
04/14/2012 7:06 AM
Ammonia and water react together quite strongly to form ammonium hydroxide. The solubility of NH3 in any liquid water is very high, so I think you would have serious trouble trying to make a steam and ammonia mixture work as a lifting gas. Pure, or anhydrous, ammonia would be your best bet.
Given that anhydrous ammonia is widely used in agriculture, I'm not sure I understand why your interest in using it as an experimental lift gas would not be an acceptable use. It is used in methamphetamine production, but it still a major commodity chemical.
I'm presuming you are looking for a lift gas for a non-manned balloon? You are aware that NH3 does unpleasant things to humans if there's a leak? Think carefully about the safety issue -- if you have a leak, and any liquid water is around, you will suddenly end up with a caustic solution and no lift at all... Google "ammonia fountain" to see how quick the ammonia goes into solution.
Good Answers: 58
Re: NH3 Blends
04/14/2012 7:22 AM
I believe the technical problem with your idea is that you need to maintain positive pressure (with respect to atmospheric) inside the balloon. As the water vapor condenses and is drained, the internal pressure will drop. You have proposed no method for maintaining positive internal pressure.
Re: NH3 Blends
04/14/2012 9:27 AM
First why does it need to stay positive. Just asking,
But that is a moot point because the balloon is a sealed system not a vented one. and is a special synthetic like latex balloon, so think GIANT party balloon. So it is always under a slight positive pressure differential because of the stretchiness of the balloon itself.
Good Answers: 58
Re: NH3 Blends
04/14/2012 9:55 AM
You described the problem when you wrote "But the main problem is almost as fast as the water vapor is created, and put into a balloon, because of the cooler temperature, it quickly condenses back into liquid water." To achieve lift, one needs a volume of pressurized material less dense than air. The optimum arrangement would be a weightless container filled with a vacuum. This, however presents certain engineering problems that have not yet been solved.
Re: NH3 Blends
04/14/2012 12:20 PM
I think the main problem is the toxicity risk if the balloon leaks or breaks.
Re: NH3 Blends
04/14/2012 1:14 PM
Agreed,
Re: NH3 Blends
04/15/2012 3:33 PM
A New somewhat question.
Ok at sea level pressure, and temp, NH3 boils at about -32 C Or condenses at -32 C depending what way the temperature is moving.
OK Water H2O in the same conditions, happens at +100 C
Now how everyone says how NH3 loves to suck water up soo strongly.
What happens to it's boiling point?
Say by weight a mixture of 90% NH3 and 10% H2O,
What happens to the boiling point of the NH3?
Good Answers: 58
Re: NH3 Blends
04/15/2012 6:22 PM
The answer to that question was developed in 1801 by John Dalton. See http://en.wikipedia.org/wiki/Dalton's_law In short. both gasses behave independently of each other.
Re: NH3 Blends
04/15/2012 6:51 PM
Dalton's law of partial pressure is only valid for non-reactive gasses. NH3 and H2O are definitely reactive to each other.
See if you can find a phase diagram for the mixture of ammonia/water you are considering.
Re: NH3 Blends
04/15/2012 11:27 PM
I have been trying to fin something like that all day with no luck,
Joe
Re: NH3 Blends
04/16/2012 12:46 AM
I'm not sure, but you might have some luck by searching on "absorption refrigeration" or "ammonia absorption." I think I have seen such charts, but I don't remember just where.
Re: NH3 Blends
04/16/2012 5:21 AM
Try Perry's Chemical Engineering Handbook. You may also see the following link:
http://www.lpi.usra.edu/meetings/lpsc1994/pdf/1278.pdf
Good Answers: 58
Re: NH3 Blends
04/16/2012 8:06 AM
A largr part of the NH3 - H2O phase diagram can be found here. http://www.lpi.usra.edu/meetings/lpsc1994/pdf/1278.pdf
Good Answers: 58
Re: NH3 Blends
04/16/2012 9:32 AM
You are correct, however, the question is do they react at pressures around 1 atmosphere and temperatures one is likely to encounter on earth? The phase diagram appears to indicate they will react as independent gasses.
Re: NH3 Blends
04/16/2012 9:49 AM
Thanks Everyone for trying to help us out here. You all do not know how grateful I am.
I will check out the above suggested links. closer, but the one I did look at with a glance is all talking about pressures. We need behaviors in cold and vacuums.
0C and down and pressures less than 1 ATM.
Joe
Register to Reply 24 comments
Doorman (1); howardlhall (2); Learner42 (1); Mr. Truman Brain (1); NSS (9); sawmilleng (2); SolarEagle (1); Tornado (2); welderman (5)
