Previous in Forum: Spare Parts List of 06NW Screw Compressor   Next in Forum: Strongest Cross Section Geometry
12 comments
Shaft Angle Finding Device (Sensor and Instrument With Dial and Pointer)
04/17/2012 12:23 AM
we are design one rotating equipment.
In that shaft will rotate 360degree . shaft will rotate one complete rotation(360 degree) in 1 minutes ( 1 rpm).
we need one shaft angle finding device (sensor and instrument with Dial and pointer)
please suggest any equipment is available at market
example : suppose we stop the equipment in 30 second , that rotating angle device pointer will show the 180 degree
Re: shaft angle finding device (sensor and instrument with Dial and pointer)
04/17/2012 12:29 AM
04/17/2012 12:49 AM
thanks for reply.
in your reply , you have given only sensor details . i want the anglr indicating device also ( pointer and dial arrangement)
04/17/2012 12:32 AM
04/17/2012 12:47 AM
70 mm dia shaft is rotating by motor .
motor speed is 1 rpm.
we need the sensor and angle showing instrumnent
example :
1 minute = 360 degree or 0 degree
15 second = 90 degree
30 se = 180 degree
the shaft is rotating continously . every one minute the the pointer cross the 360 degree
Good Answers: 104
04/17/2012 1:21 AM
Does this equipment have electrical/electronic controls (PLC, LCD display panel, etc)? If so, any controls engineer should be able to display an encoder input as a dial on a HMI (human-machine interface). Or, if no other electrics, use a selsyn (Google it). Or, for a purely mechanical approach, use a cable like the old mechanical tachometers and speedometers.
Or this
04/17/2012 2:31 AM
it is mechanical approach .
do you know the supplier for the sensor and angle indicating instrument
Good Answers: 38
04/17/2012 4:17 AM
Re: Shaft Angle Finding Device (Sensor and Instrument With Dial and Pointer)
04/17/2012 10:17 AM
Paint an arrow on the end of the shaft. Put a protractor dial around it.
04/18/2012 10:11 PM
You are designer of the rotating equipment and asking for sensor and instrument for showing angle at 1 RPM. Do'nt you think you are asking for a complicated thing for simple angle indication which can be made or 'design' by your self.
Good Answers: 104
04/18/2012 10:20 PM
Don't question OP's abilities. He's liable to unleash on you (and then release the data he withheld).
04/18/2012 10:24 PM
i agree your point. but in my application we need one shaft angle indicating gauge in front of the equipment so
i have plan to take input using cable(mechanical ) or encoder (electrical ) from shaft and show the shaft angle using indicating gauge in the front of equipment .
both ( cable and indicating gauge ) are locating in the separate plate
this is like speedo meter with cable .in that it will show the speed .
but my application i want to show the shaft angle between 0 to 360
Good Answers: 50
04/21/2012 4:55 AM
Heck the iPhone has an app that reads angles and also acts as s level.
Register to Reply 12 comments
bigg (2); Epke (1); kandakumar (4); lyn (1); Mukesh0861 (1); SolarEagle (1); Tornado (1); vermin (1)
