Previous in Forum: Strongest Cross Section Geometry   Next in Forum: What is Difference Between Propeller and Impeller Shaft?
13 comments
How to Select the Motor Power
04/17/2012 1:17 AM
we are designing one rotating equipment .
Gear motor is used to rotate the shaft. shaft is placed horizontal . bearing is placed two end the shaft .
centre of the shaft 2000 kg is acting perpendicular to the shaft.
gear motor out put speed is 1 rev per minute .
how to select the power (kw ) of the motor
Re: how to select the motor power
04/17/2012 1:24 AM
You will select the power of the motor based on the calculations you did to arrive at the power requirements of the system you are designing. You give no useful information here.
Hire an engineer with the correct experience for the job. Looks like you need one badly.
04/17/2012 1:28 AM
what information you need to calculate the power
04/17/2012 1:30 AM
I'm not going to do your job for you.
Hire an engineer.
Good Answers: 104
04/17/2012 1:39 AM
I don't know how to reply politely to your question, but, frankly, you shouldn't be designing equipment if you don't understand the basics of mechanics, and this is one of the basic, if not the most basic, principles of power. Besides, you haven't given enough information for anyone to calculate the power needed. Not only do you not know how to perform the basic calculation, but apparently you don't know what data is required. I am hoping that you are a beginning student and will therefore soon cover this in class.
04/17/2012 1:46 AM
i do not know . why you escape from my question.
either you do not know answer or not .
if you do not knowm means do not reply . i will take care of it . already i have sent my calculated sheet for you reference .
i am expecting only guidance on my query. but you are not in the position to answer .
sorry i am feel very bad about u
04/17/2012 1:52 AM
pleae find the calculated sheet .
Design Calculation for power
Date:17-Mar-12
S.no
Parameter
Specification
Unit
Remarks
1Load (F)14715N
2Speed (N)1.2r/min
3Radius (R)0.035m
4Velocity(V)0.004396m/s
5Torque (T)0.06468714N.m
6Power(P)0.099672384KW
7Power(P) with FOS 20.199344768KW
Formaula
1Velocity (V) =∏xDx(N/60)m/s
2Torque (T) =(FxV)/1000N.m
3Power (P) =NxT/9550KW
Speed:-
(N)
Customer input = 50 -60 Second /360 degree
60 Seconds/360 degree =1 r/min
50 Seconds/360 degree =1.2 r/min
load :-
(F)
Micra Body600
Mounting Frame139
Mounting Frame Support50
Bearing,Coupling& other Accessories10
Human (4 persons-Approx.Each 100 kg)400
Total
1199kg
Appro. Load taken with FOS1500Kg
Radius (R)
Shaft Dia70mm
Flange Dia160mm
Imaginary Outer Dia of vehicle2050mm
Radius (R)
Shaft Radius35mm
04/17/2012 2:01 AM
There you go. You can take it from here.
Or, do you want us to send it to motor suppliers for you?
04/17/2012 2:28 AM
if our calculation is correct .
power approxi 0.2 kw is comming.
so we can go for 0.4 kw motor .
is it correct .
we can select the motor supplier . why you want to strain your self
04/18/2012 11:22 AM
As your project involves human being, it is sincere suggestion that you hire a good engineer to do calculations for your project.
Good Answers: 104
04/17/2012 2:29 AM
In the immortal words of C.B., "Good grief!"
Good Answers: 183
04/17/2012 3:21 AM
I am deeply concerned by the fact that people who are not at required level of knowledge are used for the design of equipment where human beings are involved (see spec 4 persons each 100 kg). Neither the first throw of informations nor the second gives a feeling that the designer makes more than apply a formula. I am concerned because it is not the first time we get requirements for help from people who do not understand what they are supposed to master.
I can understand that the very fast development of several economies leads to a lack of professionals but making usage of not professionals could lead to human lives loss and this is unfortunately very possible.
04/17/2012 3:46 AM
Motor power is shaft load torque mutiplied by angular velocity divided by efficiency. So, there is insufficient information in the original post to be able to answer the question.
Re: How to Select the Motor Power
04/17/2012 6:58 AM
Register to Reply 13 comments
Anonymous Poster (1); bigg (2); kandakumar (4); lyn (3); Mukesh0861 (1); nick name (1); PWSlack (1)
