Previous in Forum: Horizontal Split Casing Of Multi Stage Centrifugal Pump   Next in Forum: Which Standard to Use for Hot Oil Heater- ASME 1 or API 560
Spray Drying
04/17/2012 10:59 AM
hi,
im working about heat recovery projects for a ceramic tile company.i try not to use any gas at spray driers by heating slurry up to 250oC before spraying with recovered heat. is it possible or do you know any applications like that?
(i can heat slurry up to 250oC but do i need any other processes (like increasing pressure) before spraying?)
Re: spray drying
04/17/2012 11:05 AM
It is both possible and economically desirable.
Reply to Forum Thread
