Previous in Forum: Compressor - Model HV40100 of ELGI Reciprocating Compressor   Next in Forum: Clarification on ACAD
Refrigeration - 3.3Kv Howden Compressor
04/20/2012 7:16 AM
My plant has . 3.3Kv howden compressor. The problem is its failing to unload even at a suction pressure below the setpoint of 325Kpa,its acting as on fully open-closed(slide valve)ie at start up its 0% and at running at 100%. The solenoids for the slide valve are in good condition. failure of it to unload causes it to continuosly draw large current and this is costly. how best can i attack the problem at hand. Help
Pathfinder Tags: refrigeration
Re: Refrigeration - 3.3Kv Howden Compressor
04/20/2012 8:50 PM
04/20/2012 10:10 PM
This sounds like a hydraulic valve actuated by load and unload solenoids. If so, it is possible that the "spool" and/or its housing have become worn, allowing oil leakage through the valve without corresponding movement of the slide valve.
Good Answers: 181
04/21/2012 12:41 PM
04/28/2012 2:40 AM
Hello....I am facing the same problem with my compressor. Can anyone help me out ? Thanks in advance.
Register to Reply 4 comments
MarkhamCornoit (1); SolarEagle (1); TonyS (1); Tornado (1)
