Previous in Forum: Leak Detector   Next in Forum: Friction Between Two Curved Surfaces
Gas Flow
04/23/2012 2:54 AM
Dear Sir,
I have Flue gas flow through a 24" pipe is around 10000Nm³/hr with suction of negative -2mmWC.If I change the pipe dia by 18" keeping suction negative -2mmWC as it is ,then what is a flow through it.
Regards
Re: Gas Flow
04/23/2012 3:23 AM
It will be according to the Darcy-Weisbach equation.
Good Answers: 137
Re: Gas Flow
04/23/2012 4:09 PM
If the pipe is long and straight, so all the loss is due to friction, flow for a given ΔP varies as 5th power of diameter. If it's mostly local losses, bends, valves etc, it's the 4th power.
