Previous in Forum: 3 Cycles Simulated PWHT   Next in Forum: Preheating of Weld Joints
RPM of Mill
04/24/2012 12:15 AM
we have calculate rpm of mill having data as. girth gear teeth 160 pinion gear teeth 23 gear ratio 1:8 motar rpm 991 plz discuss how can rpm of mill is calculated.
Re: rpm
04/24/2012 12:31 AM
1.8x991 or 1.8/911.
You don't say which end is driven.
Good Answers: 181
Re: RPM of Mill
04/24/2012 7:00 AM
For a mill drive it's not going to be 1/8
991RPM in to 8/1 gearbox gives 123.87 output to pinion
Girth gear / pinion ratio = 6.95
123.87 / 6.95 = 17.8 mill RPM
Good Answers: 181
Re: RPM of Mill
04/24/2012 3:59 PM
If we use lyn's suggestion of a gearbox ratio of 1/8 the mill would be a centrifuge rotating at 444.8 RPM!
Re: RPM of Mill
04/25/2012 10:25 PM
If the pinion is mounted directly to the motor, 991 x 23 ÷ 160 ≈ 142 rpm of the mill.
If the 1:8 is an additional gear reduction between the motor and the 23T pinion, then the mill rpm would be about 18.
Good Answers: 181
Re: RPM of Mill
04/26/2012 11:18 AM
As I said 17.8 rpm which would be about right for a mill.
I'm just going on past experience with them.
Re: RPM of Mill
04/27/2012 12:07 AM
Yes, you are exactly right.
I have some work exp. with the similar mill..........
Experiance will come with time, but you have to manage quality time. Bad management always leads us bad experiance.
Re: RPM of Mill
04/27/2012 12:05 AM
Ask Mr. Raihan/or Mr. Silvarag about this question, they have all the relevant information you required.
Register to Reply 7 comments
bashir01219 (2); lyn (1); TonyS (3); Tornado (1)
