Previous in Forum: Small Converter Efficiencies   Next in Forum: Voltage Drop Problem.
20 comments
Calculation Of Heat Generated By Control Panel Elements
04/25/2012 1:17 AM
how can i calculate heat generated by control panel elements like contactors & overloads
India - Member - New Member
Good Answers: 164
Re: Calculation of heat generated by control panel elements
04/25/2012 1:38 AM
The manufacturer's catalogues give these values usually. Here are a couple of samples from ABB....
04/25/2012 1:44 AM
Dear sir
can u tell me the calculation procedure for heat generation of all the equipments
Good Answers: 164
04/25/2012 2:18 AM
They are measured, not calculable usually. Lots of experimental data is always available with good manufacturers.
Maybe with new Thermal FEA software, one can perhaps calculate, but in my days, we did not achieve any high level of confidence in the calculation.
Please remember, manufacturers give pessimistic values. Actual wattloss figures are likely to be lower.
04/25/2012 2:35 AM
actually i want to connect an ac to my control panel so what will be its temp. rating i want to calculate
Good Answers: 164
04/25/2012 2:47 AM
i think you need to give more information.
What is the AC (i assume you mean an airconditioner) supposed to cool...the whole control room? or the control panel?
For the purpose of deciding the AC, you say you need the wattloss figures of components used in the panel. Why? And, what about busbars, enclosure class(IPxx) etc. ?
Details, with proper punctuation, will help.
04/25/2012 3:00 AM
i have to provide the ac for control panel.The details are given bellow.
Contator
25A-2
12A-2
9A-3
MPCB
20-25A-2
2.5-4A-3
4-6.3A-2
CHOKE(15HP)-2
CONTROL TRANSFORMER-1(450VA)
PLC-
CPU-1,DI/O MODULE-1,AI/O-1
3 1-P MCB,1-2POLE MCB
2 - vfd's of 11kw
04/25/2012 4:49 AM
Calculate the power flowing into the panel and the power flowing out. Subtract one from the other and that figure will be the power dissipated within it.
04/25/2012 4:50 AM
Air conditioning is to provide comfort control.
Cooling is provided by increasing the ventilation, perhaps using (a) fan(s).
In either case, basic data such as the local ambient atmospheric conditions is a cornerstone to the sizing!
04/25/2012 2:58 AM
04/25/2012 4:22 AM
Thanks for the help sir
04/25/2012 4:31 AM
Dear sir, what will be the heat generated if we connect a contactor of 24v dc for 30 min.
04/25/2012 4:47 AM
No-one can answer the question without knowing the resistance of the contactor coil.
04/25/2012 4:50 AM
Ok sir i ll give u the resistance of the contactor on friday
04/25/2012 4:53 AM
The calculation can be done right now!
  • Power dissipated is the voltage squared divided by the load resistance.
04/25/2012 4:09 AM
As an order-of-magnitude first estimate, take the incoming voltage and multiply it by the panel's measured current.
04/25/2012 4:54 AM
Do the same for the power leaving the panel to various loads. The difference is the power dissipated.
Re: Calculation Of Heat Generated By Control Panel Elements
04/26/2012 2:13 AM
The Switchboard/MCC/Control panel manufacturer should calculate and provide ventilation facilities for his panel considering ambient conditions.
pnaban
India - Member - design engineer Engineering Fields - Electrical Engineering - New Member United Arab Emirates - Member - New Member
04/26/2012 5:50 AM
http://cr4.globalspec.com/thread/71067#newcomments
Schneider Climasys
go to download documents & then download the software...
or go here schneider enclosures
i think these should help u out assuming you are asking about cooling the panel and not the entire room.....and why do u want to provide AC ? ventilation Fans are enough for control panels.
shamith gambhir, electrical engineer
04/26/2012 11:29 AM
i want to calculate as per the costumer requirement.
they needs it i.e. how much heat is generated during the work
Good Answers: 804
04/26/2012 1:03 PM
Quickest way is to assume the worst case and provide enough cooling to take care of it.
If you have a control power transformer or DC power supply, ASSUME that 100% of the rated capacity of that device is turning into heat INSIDE of the control panel. The only thing that would not be is anything that the control circuit is powering that is OUTSIDE, such as solenoids or external sub-control assemblies. So if you have a 1000VA CPT and nothing being powered outside of the panel, you ASSume that you have 1000W of heat rejection inside. Might be overkill because rarely are CPTs fully loaded, but it's a safe bet for A/C sizing. Alternatively if you use line power for your controls look up the data on each and every coil or power supply or pilot light in the panel and look at the watts consumption or rating. Again, 100% of that energy is going into the control panel in one form or another.
Then look at the power devices such as contactors, switches and circuit breakers and ASSume 0.1% voltage drop across each of the power contacts, anything more and the mfrs are in trouble (the value should always be in milivolts). Then calculate the resistance that represents and using your expected line voltage, calculate the worst case watts loss that represents.
If you have circuit breakers or overload Relays that have bi-metal thermal sensing elements, they are figured at 9W per phase each, that's the maximum design allowances for manufacturers, anything more and they get in trouble with regards to component sizing. If you use solid state OLs or CBs, don't count them, no heat losses to speak of.
If you have VFDs or other types of drives, assume 3% of the max power rating of the drive as heat rejection into the box. So if it is a 10kW VFD, assume 300W of heat rejection.
If you have a soft starter or other SCR based power device WITHOUT a bypass contactor, assume 4W per running load amp per phase; with a bypass contactor, assume it is the same as any contactor per the above.
If it is anything big enough to have bus bars, most likely it's a switchboard or Motor Control center, and the mfr will have guidelines on determining heat rejection.
Register to Reply 20 comments
JRaef (1); kvsridhar (3); pnaban (1); PWSlack (6); Rashmi Ranjan Dash (7); SHAMITHGAMBHIR1 (1); SolarEagle (1)
