I am looking for a fluid cooler that can handle 300 to 650 degrees F, The fluid is Dowtherm A. The temp range varies from 300 to 650 degrees F depending on time of day, and the pressure ranges from 40 psi to 150 psi max, My objective is to cool the fluid down to approx 250 to 300 degrees constant for our system to work with this fluid. Also the flow rate through our system is approx, 350 to 400 gph. I am new to this and do not know if anything like I need is out there. Have searched many web sites, but has been very hard to get any answers.
