Previous in Forum: How do I find the right fluid cooler?   Next in Forum: Design Pressure as MAWP
6 Stage Blower Vibration Issues
04/26/2012 2:49 AM
Hi there,
I've been encountering some vibration issues on my blower setup.
Motor (1500RPM)-Gearbox-Blower (4200rpm)
Installation and pre-startup was carried out properly. However upon starting up, the outboard vibration increases and triggered to trip at 13 mm/sec PK.
Could it be the thrust clearance issue?
Re: 6Stage Blower
04/26/2012 3:19 AM
It could be a number of things and a site visit from the equipment manufacturer's local technical representative with a view to eliminating them is thoroughly recommended. Is there a telephone nearby?
Popular Science - Cosmology - New Member Engineering Fields - Civil Engineering - New Member Engineering Fields - Nuclear Engineering - New Member United States - Member - New Member
Good Answers: 38
Re: 6 Stage Blower Vibration Issues
04/26/2012 10:32 AM
PW's right. The list of causes for vibration is long and numerous and in all likelihood would be extremely difficult to diagnose via the net.
Sometimes my thoughts are in a degree of order so high even I don't get it...
Good Answers: 137
04/26/2012 3:21 PM
Might be caused by surge. Have you checked the delivery system is as design, not causing too high pressure/low flow eg by excessive throttling?
04/28/2012 8:28 AM
Surge or thrust clearance you are right
Register to Reply 4 comments
ChaoticIntellect (1); Codemaster (1); moamen84 (1); PWSlack (1)
