Previous in Forum: Desiccant of IA Dryer   Next in Forum: Weight of hourglass
12 comments
Instant Cooling of Very Small Material
04/26/2012 12:09 AM
I am cutting very small diamond stones through laser beam of energy 1 to 3 mJ.
I want to cool the object instantly.
What is best method can be use? TEC, Vortex tube or a particular material having property to cool up to 4 Deg C.
User-tagged by 1 user
Re: instant Cooling of very small material
04/26/2012 1:37 AM
Submerge in ice water.
That's a first option; there may be other possibilities.
Re: Instant Cooling of Very Small Material
04/26/2012 9:26 AM
04/26/2012 3:19 PM
CO2 fire extinguisher.
Just remember to ensure the diamond is securely fastened down least it fly off.
Good Answers: 150
04/26/2012 3:36 PM
spray liquid Nitrogen (or Liquid CO2 would probably work too.) on it. that is about as instantaneous as you are ever likely to get.
Who is John Galt?
04/26/2012 4:38 PM
Good Answers: 150
04/26/2012 4:42 PM
So you aren't worried that Thermal Shock won't cause them to shatter?
Who is John Galt?
04/27/2012 12:42 AM
There is no such thing as instant cooling! All cooling processes take time! As someone has already suggested, spraying with liquid N2 is about as close as you are going to get to instantaneous.
As someone else suggested, if you cool it too rapidly, it may shatter...
Good Answers: 150
04/27/2012 2:08 PM
dkwarner, one bit in the OP's favor is that diamond is about as close to a thermal superconductor as there is.
Who is John Galt?
04/27/2012 11:49 PM
Right you are! I only learned that little tidbit a year or two ago, and found it quite difficult to believe at first, since most materials that are good insulators of electricity, which is to say poor conductors of electricity, are also poor conductors of heat. I did just get out the Ohmmeter to verify that a diamond is indeed a poor conductor of electricity, at least the two or three I tried...
Good Answers: 150
04/28/2012 9:06 AM
IC manufacturers are trying to figure out how to grow the silicon and/or Gallium Arsenide on a sputtered diamond substrate as a heat spreader plate.
Who is John Galt?
Good Answers: 19
04/27/2012 2:04 PM
How Many?
How fast?
How often will you need the cooling solution?
If it is set up as an assembly type of process, Tornado's suggestion is good, ice bath or glycol fluid bath with a conveyor at the bottom to pull the diamonds back to the surface into a storage vessel.
Or make a nitrogen injection tunnel like we did for mini quiche. Came out of the oven at 475 degrees 30 feet later into packaging at -15 degrees.
Good Luck
05/03/2012 3:32 PM
experiment before you buy. I have had diamonds shatter from rapid cooling after doing jewelry work.
dkwarner (2); jack of all trades (1); kramarat (1); lyn (1); Rorschach (4); silvCrow (1); Stedou73ish (1); Tornado (1)
