Previous in Forum: How To Calculate The Machine Tonnage For Parts Of High Pressure Die Casting?   Next in Forum: How to Calculate Compressibility Factor for Helium Gas?
10 comments
Over Flow From Tank
04/27/2012 6:57 AM
Could anybody tell, how to decide the size of hole in the water tank to avoid the raise in level of water above that position of hole when pump keeps running? How i can use the law of energy and mass conservation here?
The flow rate of water into the tank through pump is 300lpm.
Good Answers: 38
Re: Over Flow From Tank
04/27/2012 7:37 AM
Banu,
Please try at least to make at least a weak attempt by yourself to investigate your issues.
There is a wonderful tool called "GOOGLE" that, when used by the competent, can answer many questions.
Froude, Banu, Froude...
Good Answers: 179
04/27/2012 10:37 AM
You need to calculate the discharge (flow) value of the orifice, weir or overflow pipe. The discharge must be in excess of the pumping delivery flow to the tank, which you gave as 300 Liters per minute.
This is "Hydraulics 101". Were you sleeping in class again when the Professor discussed this?
04/27/2012 11:57 AM
Why not trim the top of the tank to the desired full level?
Then the question of overflow sizing is then solved.
04/27/2012 1:03 PM
As mentioned above you have to size an orifice to meet atleast pump flow. But flow to happen through orifice, water head required above that. So you can hole little below the desired level and let water go to your desired level and for that head, size the hole to meet pump flow
04/27/2012 1:12 PM
"... [then simply] size the hole to meet pump flow" The size of this single overfill relief hole is the question. It is inferred that the smallest size is desired. A horizontal slot will be better than a round hole... I guess. There are many things undefined, but homework questions usually are not well defined.
Why are you answering your own question?
04/27/2012 10:26 PM
Is there any problem with making the hole larger than necessary, say 4" (100mm)?
Good Answers: 19
04/28/2012 12:10 AM
install a float level valve (mechanical) or a flow level switch (electrical) to shut off pump.
Good Answers: 179
04/28/2012 9:28 AM
Using a float or switch (to de-energize the pumps) level control would be ideal, but many codes like AWWA require an overflow pipe/outlet on storage tanks.....it makes the overflow issue sort of "idiot-proof" in the event of a power outage or disruption, etc..
Good Answers: 38
04/28/2012 12:25 PM
All of the above comments are very nice, but the do not address Banu's original question about tank overflows...... How are they to be sized ?
What does an overflow do anyway ?...Is this flow "self venting flow ?
Froude, banu, Froude !
(William Froude an English engineer, did the original theoretical work..)
C'mon banu, you can do it !....
Here are some hints...... GOOGLE and Froude !!!
Good Answers: 179
04/28/2012 12:34 PM
I strongly suggest that the OP obtain a copy of Brater & King's Hydraulic textbook and let him figure it out all by himself. there are free ebook downloads of this text available on the web, if you look hard enough.......try a Google search.
A lot depends on the orifice configuration (re shape, hence applicable coefficients) and depth of head, in addition to the diameter of the orifice.
Anonymous Poster (1); CaptMoosie (3); Doorman (2); ducon (1); MJCronin (2); Tornado (1)
