Previous in Forum: Liquid Aluminium Transportation   Next in Forum: Percentage of Waste in Manufacturing a Buttwelded Carbon Steel Tee
Calculation of Steam Required
04/30/2012 4:55 AM
Hi
I want to calculate the steam requirement @16 bar for drying a liquid with 50% solids in spray drier . Please let me know formula for same and also how steam requirement changes with change in humidity of ambient air.
Re: calculation of steam required
04/30/2012 5:00 AM
That would depend upon the vacuum level in the dryer, the minimum acceptable moisture level, the maximum temperature in the dryer, the quality of the steam and a whole host of other things.
Engage one or several dryer vendors in a pilot-scale trial. Most dryer vendors are happy to participate, because as well as the prospect of a sale, the vendor will both bring recent application knowledge gained from elsewhere to the party and glean application knowledge from it that can be taken to the next one.
Good Answers: 19
Re: Calculation of Steam Required
05/01/2012 3:09 PM
You mean to say that you want to dry solids with 50% moisture content with steam at 16 bar? What is the solid (wood/Tobacco/bagasse/rice/wet leather etc)? what is the quantity kg/hr? what is the specific heat of the solid? waht temperature wet in? what temperature dry out? what % m.c in the solid at exit?
Register to Reply 2 comments
