Previous in Forum: Regarding Mechanical   Next in Forum: Pipe Mill Tolerance and Required Reinforcement
MTU Engine
05/03/2012 2:15 AM
there is delay in achieving rated speed by our MTU engine. what are the reason behind it?
Re: MTU Engine
05/03/2012 3:04 AM
Can you describe the mechanical and/or electrical loads driven by this engine, and how they are sequenced into operation?
Re: MTU Engine
05/03/2012 3:09 AM
Big flywheel?
Re: MTU Engine
05/04/2012 3:19 AM
Mismatch between the MTU engine performance curve and the load characteristic curve, making the intersection of these at the wrong place?
Re: MTU Engine
05/07/2012 1:46 AM
Engine can not achieve rated speed at no load
Re: MTU Engine
05/07/2012 2:00 AM
If unable to reach speed under load, but able at no load, I would suspect a fuel problem such as plugged filter, contamination in fuel, etc.
If unable to reach speed even with no load, this could be a governor problem, or maybe a sticky fuel rack linkage, or something like that.
My experience is limited; I've run out of ideas.
Good luck solving this!
Re: MTU Engine
05/07/2012 3:49 AM
What is the meaning of MTU? I'm sorry but this is new to me. thanks.
Register to Reply 6 comments
Dback (1); Faiz6555 (1); PWSlack (2); Tornado (2)
