Previous in Forum: Electrical Code Question   Next in Forum: A.C. Question
Guideline for CT and PT Ratio Selection for an Energy Meter
05/05/2012 3:28 AM
Dear Forum members,
I am doing research work on drilling of a glass fiber reinforced polyester resin composite.
During this process, I am recording energy consumed during drilling of this composite by varying its glass fiber percent proportion. The energy meter I am using is a CE certified Nanovip meter.
My question is how to select CT and PT ratio for a particular job? Should it be different for steel,aluminium,wood or say for composites?
Are any guideline available for the same?
Thanking you.
Re: guideline for CT and PT ratio selection for a energy meter
05/05/2012 4:21 AM
What is the anticipated current for the drill motor; what current range does the meter accept as input? Similarly, what is the motor voltage, and what voltage input does the meter accept?
05/07/2012 4:19 AM
Thank you very much.
Today I drilled the fiber reinforced plastic sample with a 10 mm drill and noted the results with the energy meter. Can you please provide me your e-mail id so that I can send the output screen to you and present CT and PT ratio for further evaluation.
Good Answers: 445
05/05/2012 8:10 AM
Nice little meter:
http://www.instrutek.no/productSheets%5CElcontrol_Nanovip.pdf
There's even enough information on their website for a qualified technician to answer OP's questions in combination with Tornado's suggestions, and a little effort and experimentation on OPs part.
Register to Reply 3 comments
Anil123 (1); RAMConsult (1); Tornado (1)
