Previous in Forum: Special WPS/PQR For Welds That Require Post Weld Heat Treatment   Next in Forum: Problems About Pipe and Temperature
Water Treatment Problems
05/11/2012 10:17 PM
I come across problems as follow,
raw water source is brackish water, its TDS is 3500ppm. customer need water treatment system, which can have largest of water recovery. and output water is required TDS 500ppm.
but as for reverse osmosis system, its recovery is about 50-60%. customer is not satisfied with this technology.
as for ion exchanger, it's not suitbale for brackish water. when it run for short time, it needs regenration.
is there anyone help me?
thanks.
cookee
www.serieswater.com
Re: Water treatment problems
05/11/2012 11:16 PM
I can help you. Call me. Your RO system is not keeping up with the ion exchange ratio of the system.
Good Answers: 179
Re: Water Treatment Problems
05/12/2012 11:43 AM
Is the raw water source a surface water or a well water? I suspect that it's a surface water based on the information provided so far.
I don't think that RO is going to be helpful you. With such a high TDS you may have to provide tradition treatment unit processes, such as preliminary settlement followed by chemical dosing, flocculation & coagulation, and settlement. You must perform "Jar Testing" of various dosing chemicals to determine the most effective and economic ones for the treatment train.
You are a Civil Engineer specializing in Water Treatment, aren't you?
05/17/2012 3:33 AM
The recovery ratio depends upon the detailed design and configuration of the system, which in turn depends upon incoming water quality and flowrate.
Most, if not all RO membrane vendors provide software to enable the correct configuration to be determined with little effort. Do contact some and obtain at least one package to enable "what if" calculations and various schemes to be prepared. They can even be demonstrated to this client.
Good Answers: 101
05/19/2012 8:18 AM
You'll need a two-stage RO system to reduce the TDS content first. This may require to be followed by a DI system should the second stage permeate TDS level still be too high.
CaptMoosie (1); DVader1000 (1); lyn (1); PWSlack (1)
