Previous in Forum: Temperature Sensor Insertin for Natural Gas   Next in Forum: 2 Sigma Value
Orifice Flow
05/12/2012 10:44 PM
For an orifice plate
Operating pressure is 30 bar.
Max flow 13000 NM3/Hr.,
DP 1000 MMWG
If this pressure is 12 bar & other parameter is same, then flow will be affected or not?
Re: orifice flow
05/13/2012 4:55 AM
Now the pressure before the orifice is 30 B and after the orifice 29.902 B (delta P 0.098 B, or 1000 mmwg).
If the pressure before the orifice is lowered to 12B, then flow will decrease, the delta P will become less (for instance, 0.04 B)
Re: Orifice Flow
05/13/2012 4:48 PM
Among other things, it depends if the fluid is a gas (density will change) or a liquid (no change). The 13,000 Nm3/h indicates a gas.
Re: Orifice Flow
05/16/2012 6:57 AM
sir
Accuracy of flow readingchange if pressure change even rise or decrease ie we use flow compensation farmula with flow measurement.
Register to Reply 3 comments
Lalit Shukla (1); Tornado (1); Yuri B. (1)
