Currently I am developing a Radiator by cold rolling steel sheet of thickness 1.60mm with the help of single stand rolling mill using one pair of roller set of diametre 270mm.The purpose of rollers is to develop the grooves in the sheet.Two such sheets are then spot welded.
While I am able to get the groove profiles developed in the sheet satisfactorily, I am finding severe wrinkle formations in the edges ,both the sides, all along.The roller is checked for its alignment which is found to be satisfactory.Hardness of the sheet is also verified and the same is found to be consistent.I would like to know what could be the other reasons for such problem?
I would also like to know about the design fundamentals for building a Spot Welding Machine for cold rolled steel sheets of the thickness 1.60mm and for 3.15 mm .
Regards!
Shah D.
