Previous in Forum: Looking for an Inverter Circuit Using SG3524 PWM   Next in Forum: Who Can Afford to Build ICs?
Satellite Receiver
05/10/2007 11:42 PM
Hi
i have satellite receiver technosat before its working fine but suddenly stop working. when i go to installation channel its not showing satellite the satellite list empty i checked all my cable everything is fine. i tried a lot what i couldn't find any solution
help me please
Pathfinder Tags: satellite receiver
Good Answers: 54
Re: satelitte reciever
05/11/2007 7:08 AM
I have absolutely no experience with satellite receivers but I'm going to hazard a guess.
Your satellite dish has shifted position or elevation.
Other than that, I'd advise you to consult your friendly neighborhood technician.
05/11/2007 10:26 AM
I'm pretty sure it's because your satellite has been destroyed by a comet. Or else you've bumped your dish. Or maybe lightning blew out your receiver. Have you tried calling a technician?
Re: Satellite Receiver
05/12/2007 9:25 AM
high wind can knock out a dish's alignment very easily-has happen to me on several occasions to both 8'-10' and now the small dishes. Realign !!!!!
05/12/2007 10:49 AM
If the dish is in perfect alignment, then it sounds like the LNB is bad. The LNB is the device that is on the end of the arm that aims towards the center of the dish. Without this device functioning, you will not receive any signal. You can get a replacement LNB at RadioShack, ADI or your satellite provider. A few screws and one or two coax connectors, the LNB comes right out.
Good Luck!
Jeff
05/12/2007 11:54 AM
If the satellite list is empty that likely means your descramble card module has failed. Try to reinitialize the system, pull the power off for 3 minutes and start over. Sometimes lightning and voltage surges on the AC or phone line can zap the receiver/descrambler module.
bhankiii (1); CNCdoc (1); Dr.Tom (1); JLD2896 (1); Vulcan (1)
