Previous in Forum: 2 Sigma Value   Next in Forum: Pressure Transmitters
Level Switch
05/14/2012 8:03 AM
Is level Switch is NC contact type or NO contact type?
I'm very much confusing for this.
Pathfinder Tags: level switch
Re: Level Switch
05/14/2012 8:41 AM
Depending on the desired function, it could be either one.
How to Search the Internet Effectivel
Relay - Wikipedia, the free encyclopedia
Re: Level Switch
05/14/2012 9:43 AM
thank you....
Re: Level Switch
05/14/2012 9:39 AM
Most level switches I have used come with both a NC and a NO terminal - which you use depends on your desired operation.
Re: Level Switch
05/15/2012 3:28 AM
...it also depends upon whatever is 'normal' in the process. A low level switch will be normal above the trip point. A high level switch will be normal below the trip point. Both devices could be the same switch assembly. So it's the process conditions that determine normal.
Register to Reply 4 comments
lyn (1); Phys (1); PWSlack (1); Rajeshkannanm (1)
