Please let me know what should be the variarion i can bare?
I have 1000 l tank, 04 nos loadcells located at each legs of tank
display connected with it has a resolution of 0.5 kg. I have set capacity parameter of display is 1500kg.
The make of loadcell is metlar toledo.
I am calibrating this loadcell using standard weights.
the calibration range is 40 to 1000 kg.
Normally weighing balace have accuracy of +/- 2d.
My question is that what should the acceptable error for displyed weight with comparition of standard weight for above mentioned calibratiin range.
Should it be +/- 2d at 40 kg and also for 1000 kg.
At 1000 kg i could not gate this accuracy
Final question is that what should the accuracy for min weight and max weight?
Muktesh Suthar
