Previous in Forum: Motor Frequency   Next in Forum: Electrons Contribute To Rust?
Frequency Change
05/18/2012 5:42 AM
What ill be impact if the Frequency changes from 50Hz to 60Hz in an electrical circuit
Re: Hi
05/18/2012 6:03 AM
Well, it rather depends on what the circuit consists of, which cannot be seen from here. If it were a synchronous clock, for example, it would run at 60/50 times its design speed, and only show the correct time about twice per day.
Good Answers: 804
Re: Hi
05/18/2012 12:33 PM
About twice per day? You mean there's a chance it could be correct three times per day?
Engineering Fields - Control Engineering - Newby Member Long Time User Engineering Fields - Instrumentation Engineering - New Member
Re: Hi
05/19/2012 9:44 PM
How would you ever know that it was correct.
Re: Frequency Change
05/18/2012 3:44 PM
05/20/2012 4:13 AM
the effect of changing the frequency is also the cycle of all eletrical equipment, thats why today we have all king of equipment that have a auto HZ frequency, this application is to protect our appliances<
i want ot helf piple need assistance and to share my knowleged in technical
Good Answers: 42
05/22/2012 8:01 AM
Ego clash between US and UK engineers .
05/24/2012 6:27 PM
One of the answers is given by Mr. PWSlack GURU.
I will try to explain some other affects.
Well known Voltage equation for AC equipment based on Induction principle is
1. For Transformer: V=4.44xAxBxFxN----------1(for Transformers & Induction Motor)
Where: V= Volts; A= Area of magnetic circuit in M2; B=Flux density Web/M2; N= number of turns F= design frequency & FN applied new frequency.
For transformer: V=4.44*A*(B*FN /F)*F*N; Therefore; Iron losses will decreases
------------------------------XXXXX---------------------------
2. For Induction Motors (Pumps & Fans): Speed N= F/p
Where: N =Speed of the motor; F= Design frequency; p=pair of poles; FN =applied frequency
NN =FN*(N/F); Speed increases so the effects are
1. Volume Flow (Q=M3/s) varies as: QN = (NN / N)*Q; So Flow increases
Head (H=Meter) developed varies as: HN = H*(NN/N)2; So Head increases
Power (P) absorbed varies as: PN = P* (NN /N)3; So Power increases
Similarly follows Fan motor.
-----------------------XXXXX--------------------------------
3. For impedance of cable or wire:
Inductive (L) impedance per unit length: Z = R+J 2πF* L; impedance value increases
Capacitive(C) impedance per unit length: Z = R+1/ (J2πF*C); impedance value decreases
Where: Z, R, L & C are Impedance, Resistance, Inductance & Capacitance respectively:
--------------------------XXXXX----------------------------------------------
4. In Long Transmission Line: Wavelength, velocity of propagation of wave and frequency are λ, ν and F respectively.
Velocity of wave propagation given as: ν = F* λ miles per second. The typical values for 60Hz are as follows:
V= 182,580 miles/second
λ= 3043 miles; Velocity of propagation of wave increases
B.E, M.I.E, M.S
Register to Reply 7 comments
BDThompson (1); JRaef (1); lyn (1); Mushtaq Hussainh (1); PWSlack (1); toink (1); V.I.Abraham (1)
