Previous in Forum: Variable Speed Drives   Next in Forum: Frequency Change
Motor Frequency
05/18/2012 5:36 AM
can i run 50hz 3phase induction motor on 53hz?
can i run 50hz 3phase water pump motor on 53hz?
Re: motor frequency
05/18/2012 6:05 AM
<sigh> Why not ask the pump manufacturer directly instead of wasting time on CR4?
Good Answers: 59
Re: motor frequency
05/18/2012 6:45 AM
Is CR4 ever a waste of time?
Re: Motor Frequency
05/18/2012 7:15 AM
you may run. Also check frequency tolarence indicated in data sheet. Usually +_2.5% allowed. As said above subject to motor make
Good Answers: 181
Re: Motor Frequency
05/18/2012 10:01 AM
This is the 2nd time you've asked this question!
You got a very good explanation from JR last time.
Good Answers: 804
Re: Motor Frequency
05/18/2012 12:40 PM
Maybe he suffers from that mental condition wherein people lose the ability to apply concepts consistently across changes in data.
My wife suffers from it.
Re: Motor Frequency
05/18/2012 10:31 AM
If it is a centrifugal pump, it will require (53/50)3 ≈ 1.191 times as much power as before. If the motor FLC is not exceeded, this should be okay.
Register to Reply 6 comments
GURUMOORTHY (1); JRaef (1); PWSlack (1); SavvyExacta (1); TonyS (1); Tornado (1)
