Previous in Forum: 12 V LED Light Connectors   Next in Forum: Question for "Well-Seasoned" Woodworkers...
Humidity Controlled Air Coolers
05/31/2012 6:34 AM
I am residing in a coastal area where the normal temperatures in summer will be 42 deg. Centigrade, with a humidity of 80%, i cannot afford for an air conditioner, can anyone suggest me what is the cheapest system i can go for, so as to maintain the room temperature at 26 - 28 degrees centigrade (in summer) by controlling the humidity. I was planning to buy an de-humidifier which controls the humidity. Does it work, or are there any other alternative ones.
Re: Humidity controlled air coolers
05/31/2012 6:46 AM
As the wet bulb temperature of [42degC/80%rh] is higher than 26-28degC, the desired temperature cannot be obtained by evaporation alone. Either some refrigeration ("air-con") or some loss of comfort will be necessary. Either that or passive cooling techniques embraced by 'alternative' building design and construction.
Reply to Forum Thread
