Previous in Forum: Thermal Characterization of Coal Tar   Next in Forum: Conductivity
15 comments
Static Friction (Stiction) Values
06/02/2012 12:07 PM
Where can I find static friction values for synthetic materials? I'm looking for values for plastic on plastic and plastic on elastomer - specifically PEEK on viton - but I would like to see other combinations.
I've googled,binged,wikied and wolframmed, but even the most promising looking results only give values for sliding (kinetic) friction or values for metals,stone,glass.wood,etc.
Re: Static Friction (Stiction) Values
06/02/2012 1:19 PM
How about buying some samples of these materials, some weights, and a linear scale--and performing some experiments?
06/02/2012 1:40 PM
I'm reduced to experimentation on a limited budget if I can't find the tables, but that gets too expensive to contemplate for the myriad combinations involved.
Re: static friction (stiction) values
06/02/2012 1:24 PM
ME nor Material Science is my engineering field. However, I've had to work with motion control in a wide range of environments. I doubt that you will find a single, simple answer to static friction between any two materials. Many different conditions will change the initial force required to dislodge two things in contact: atmosphere or any lubricating fluid between surfaces, deformation of either surface, cold welding, Van der Waals attraction, hydrogen bonding, redox reaction, length of time between motion. I added the length of time to this list because I believe that all of the other static friction contributers have a time based differential component that will asymptotically approach a maximum value. So one cannot easily predict what the static friction value will be.
At the same time, my motion control experience says that providing a force margin of 50% above the kinetic friction will be sufficient for overcoming the added static friction. Don't forget the force needed to get the desired acceleration.
06/02/2012 1:33 PM
Yes, I know that static friction is usually greater than 120% of kinetic friction, but where are the kinetic tables for polymers and elastomers?
06/02/2012 1:49 PM
My search is not for 'how much force is needed to overcome',rather it is 'how much force can it reliably resist before movement'.
06/02/2012 1:53 PM
Relying on static friction to keep something in place sounds like a recipe for failure to me.
06/02/2012 9:14 PM
If the static friction is 1000 lbs and the max force is only 200 lbs, then there is more than sufficient over-engineering for safety.
06/02/2012 9:50 PM
Yes, in the given condition motion will not happen. However, you're ignoring my earlier point. Static friction is not constant. A nominal maximum is 20% of the friction coefficient.
06/02/2012 10:26 PM
What do you mean by and refer to this?
06/02/2012 7:57 PM
What, exactly are you doing?
Tornado's suggestion makes even more sense now.
If you are dealing with O-rings it can get complicated.
06/02/2012 10:18 PM
I'd like to lock a 1"x1"x33" PEEK member that rides through a 4" long PEEK housing. The locking element can be elastomeric, but you see that the other side is PEEK. I could put an elastomer on that side too, but I need low kinetic friction when repositioning .
06/02/2012 10:32 PM
No O-rings. This is slab of PEEK on slab of ....
06/02/2012 11:26 PM
All that I'm looking for is a table of COEFFICIENTS OF STATIC FRICTION for PLASTICS and ELASTOMERS. I know that these coefficients have been measured.....so where are they? I see kinetic friction tables all over the place but almost none referring to plastics or elastomers.Those that do only list the outliers like teflon and nylon and "rubber" on metals,wood,stone,etc.
It's like I'm the first person in the universe to think that teflon might touch buna-n!
Just tell me where this information IS! If it's in a book, tell me! I'll buy it. If it's on the web.,give me a link...god bless you and the horse you rode in on.
06/03/2012 12:27 AM
Maybe you're just the first person on the planet who wants the information presented to them without any personal effort.
Bearings are not normally made of this combination of polymers. O-rings, maybe.
You may find Pv values, but you may have to do your own testing for this.
Manufacturers will be the best source, if the information exists..
Good Answers: 21
06/03/2012 2:55 PM
This information relevant to your requirement probably will only be obtained from your own specific testing / experimentation since the specs are going to be limited to a particular material. It's doubtful you will find something directly related to the stiction between PEEK and Viton(which one?) unless you just happen to know of a manufacturer that has done the testing for some reason.
Good luck with it though.
http://www.dupontelastomers.com/Tech_Info/techInfo.aspx
You will need to know which material you are after since Viton is simply a trademark name and there are a ton of different formulations.
http://www.interstateplastics.com/specifications.php?material=PEEK&vid=201206031324-4p
PEEK
Property
Units
PEEK
Search
Water Absorption (Saturation)%0.1
Tensile Strength (73 F)PSI16,000
Flexural Strength (73 F)PSI25,000
Compressive Strength (10% Deflection)PSI20,000
Shear Strength (73 F)PSI8,000
Impact Strength, Notched Izod (73 F)Ft-Lbs/In.1
Elongation at Break (73 F)%40
Tensile Modulus of Elasticity (73 F)PSI630,000
Flexural Modulus of Elasticity (73 F)PSI600,000
Hardness - Rockwell & Burnell (73 F)Various ScalesM100 (R126)
DensityLbs/In
Coefficient of Friction (Dynamic)
None
0.4
Wear Factor (K)in. -min/Ft-Lbs-Hr375
Limiting PVPSI/FPM8,500
Abrasion Resistance IndexNone
Coefficient of Linear Thermal ExpansionIn./In./F2.6 x 10-5
Continuous Service Temperature - in Air (max.)F480
Deflection Temperature (264 PSI)F320
Melting PointF644
Deformation Under Load (2000 PSI, 122 F)%-
Dielectric StrengthVolts/Mil480
Volume ResistivelyOhm-CM4.89 x 10-16
Dielectric Constant (1 kHz)None-
Dielectric Constant (1 MHz)None3.3
Dielectric Constant (60 Hz)None3.3
Specific GravityNone1.31
Coefficient of Linear Thermal Expansion (-40 F to 300 F) (E-831)None2.6 x 10-5
Heat Deflection Temperature @ 264 psi (D648)F
Vicat Softening Point (D1525)F
Speed doesn't kill. Sudden stops, brick walls, and old ladies in Buicks do.
Register to Reply 15 comments
lyn (2); redfred (3); Switchman (1); Tornado (1); zweibarren (8)
