Previous in Forum: Static Friction (Stiction) Values   Next in Forum: Inergon Gas
14 comments
Conductivity
06/03/2012 3:45 PM
Is quartz a good conductor of electricity or not?
Re: CONDUCTIVITY
06/03/2012 3:55 PM
Re: CONDUCTIVITY
06/03/2012 3:59 PM
Please turn all-caps off.
As to the question, I don't think so; but I didn't look it up.
Re: CONDUCTIVITY
06/03/2012 4:19 PM
Quartz is typically considered to not be a good conductor. However, the piezoelectric effect happens in a quartz crystal quite easily. Because of this a uniform crystal of quartz can be cut to a precise dimension so that a quartz crystal oscillator can be fabricated. At the corresponding frequency that the crystal has been cut to and only at this frequency, it effectively allows a signal to pass through. (Technically at this frequency, conduction still does not happen because electrical energy is changed to mechanical and then back to electrical.)
Re: CONDUCTIVITY
06/03/2012 5:14 PM
Re: CONDUCTIVITY
06/03/2012 7:20 PM
Here are a few common examples of conductors and insulators:
Conductors:
  • silver
  • copper
  • gold
  • aluminum
  • iron
  • steel
  • brass
  • bronze
  • mercury
  • graphite
  • dirty water
  • concrete
Insulators:
  • glass
  • rubber
  • oil
  • asphalt
  • fiberglass
  • porcelain
  • ceramic
  • quartz
  • (dry) cotton
  • (dry) paper
  • (dry) wood
  • plastic
  • air
  • diamond
  • pure water
Good Answers: 58
Re: CONDUCTIVITY
06/03/2012 7:43 PM
Concrete?
mike k
Re: CONDUCTIVITY
06/03/2012 8:31 PM
Concrete is, generally speaking, a poor conductor of electricity, but it is a conductor, and that increases with humidity...Here is a link to some new techniques being tested now to increase this ability, for some surprising benefits...
http://rebar.ecn.purdue.edu/ect/links/technologies/civil/conductive.aspx
Re: CONDUCTIVITY
06/03/2012 7:46 PM
Plastic?
Re: CONDUCTIVITY
06/03/2012 8:35 PM
Re: CONDUCTIVITY
06/03/2012 8:39 PM
Conductive polymer - Wikipedia, the free encyclopedia
Plastics is a very broad term and it can, indeed, be conductive.
Re: CONDUCTIVITY
06/03/2012 9:47 PM
This is from the first paragraph of your wiki link..." Conductive polymers are generally not plastics, i.e., they are not thermoformable. " These conductive polymers are generally called melanins...
Re: CONDUCTIVITY
06/03/2012 9:51 PM
Let's not get into a semantics argument about plastics and polymers.
Re: CONDUCTIVITY
06/03/2012 8:38 PM
In the case of both concrete and plastic it depends. Many plastics are formulated to not be highly insulating to prevent static build up that can harm another product. Think of the tubes and conductive foams used for shipping of chips. In the case of concrete, think of the case of the grounding of a building through the concrete foundation.
Re: Conductivity
06/06/2012 9:22 PM
No it is not usually a conductor.
Register to Reply 14 comments
lyn (4); mike k (1); redfred (2); SolarEagle (4); Tornado (1); Usbport (1); xray45347 (1)
