Previous in Forum: Insulator Question   Next in Forum: Sandwich Busduct
Transformer Markings
06/04/2012 7:56 AM
Hello
Anyone has an idea what these markings on a transformer really mean:
TSE 240V 14V
6170JB2005A 99 03 08
I know that its a stepdown transformer from 240V to 14V.
I think 99 03 08 is manufacture date.
No idea about the rest.
I need to evaluate the power/VA and current carrying capacity of the primary & secondary windings.
Thanks
Re: Transformers
06/04/2012 7:59 AM
This could be the transformer part number specific to the manufacturer.
Re: Transformers
06/04/2012 8:21 AM
I believe it's made by the TAESUNG ELECTRNICS CO. LTD. of South Korea.
Best I can do in the time.
Re: Transformers
06/04/2012 9:38 AM
I think you got it wrong. Its TSE and NOT TSF.
TAESUNG ELECTRONICS CO.LTD makes welding machines with TSF??? model format.
But thanks anyway for trying to help.
Re: Transformers
06/04/2012 9:47 AM
This was my clue:
.. from a refrigerator service document.
Must be a different Tae Sung. Over to you ...
Re: Transformer Markings
06/04/2012 4:18 PM
Looks like the manufacturers number...
06/05/2012 5:42 AM
if you can get to the actual winding (will have to gut a slit into the outer insulating paper) to determine wire gauge using a micrometer or digital vernier - I'll be able to tell you the VA rating and then your respective current ratings will be known...no need to scrape the insulation off the wire either as it's u sually thin enough of a coating to not influence the standard wire guages available. I'm a transformer manufacturer. let me know what voltage-winding you are measuring too.
Cheers
Register to Reply 6 comments
ASISHKDHAR (1); JohnDG (2); lefty900 (1); repit (1); SolarEagle (1)
