Previous in Forum: Fuse Replacement - Heater Protection   Next in Forum: Eliminating Power Lines
Electrical Conduction of Grease at Low Temperatures
06/05/2012 2:35 AM
I am using contact grease for slide in type contacts... this grease shows good conductivity at normal room temp. around 25deg...however at temperatures of around -30 the grease solidifies and after doing the contact resistance test..i find the values of contact resistance has increased...
why does this happen? is solidificaton of grease leading to this...the grease is lithium base...
Re: Electrical condution of grease at low temperatures
06/05/2012 7:01 AM
What are the temp units (ºC, ºF)?
With the conditions you describe, the behavior is not surprising to me.
Since the conductivity of the grease is based partially on the concentration of the electrically conductive component (ECC), I believe that the low temperatures are messing with the "solubility" of the ECC, thereby interfering with conductivity.
Have you contacted the contact grease supplier to see if they have a product more suited to your temperature range?
06/16/2026 3:53 AM
Re: Electrical conduction of grease at low temperatures
Hi Mikerho,
Thank you for your question. I’m a Professional Engineering Sales Manager from Vnovo, a specialty lubricant manufacturer. I’d like to offer some insights on the phenomenon you’re observing.
To directly answer your question: The temperature unit depends on the specific grease and its datasheet—both °C and °F are commonly used. However, the core mechanism behind what you're observing is the same regardless of the unit.
Why does low temperature affect grease conductivity?
The change in electrical conductivity of grease at low temperatures comes down to **three interrelated factors**:
1. Base Oil Viscosity Increases
As temperature drops, the base oil in grease becomes more viscous and can even partially solidify. This thickening effect impedes the mobility of conductive particles suspended within the grease. When conductive fillers (such as carbon black, graphite, or metal powders) cannot move freely, their ability to form continuous conductive pathways is compromised.
2. Conductive Network Disruption
Conductive greases work by having conductive particles dispersed throughout the grease matrix, creating a network of electrical pathways. At low temperatures:
- The thickened base oil physically separates these particles
- Thermal contraction causes the grease matrix to shrink, pulling conductive particles apart
- The reduced Brownian motion of particles makes it harder for them to maintain contact
This disruption of the conductive network leads to increased contact resistance and reduced overall conductivity.
3. Different Conductivity Mechanisms for Different Additives
Research has shown that different conductive additives exhibit **rather different temperature-dependent conductivity behaviors**. For example:
- **Carbon black**-based greases may experience more significant conductivity drops at low temperatures
- **Ionic liquid**-doped greases can maintain better conductivity across temperature ranges
- **Metal powder**-filled greases (copper, silver) may behave differently depending on particle size and loading
The Engineering Perspective
From a practical standpoint, what you're observing is expected behavior. Standard greases are typically formulated as electrical **insulators** (dielectric greases). Conductive greases, on the other hand, are specially engineered with specific additives to achieve conductivity.
If you're working with a conductive grease at low temperatures, the conductivity decrease you're seeing is likely due to the mechanisms described above. The magnitude of this effect depends on:
- The specific formulation (base oil type, thickener, and conductive additives)
- The operating temperature range
- The grease's low-temperature performance characteristics
About Vnovo
At Vnovo, we specialize in developing high-performance lubricants for demanding applications. Our conductive greases are engineered with:
- **Nanoscale conductive carbon black** for enhanced conductivity
- **Synthetic base oils** for excellent low-temperature performance
- **Temperature ranges** as low as -45°C to +200°C
Our conductive greases are widely used in applications requiring both lubrication and electrical conductivity, such as electrical switches, sliding contacts, and static dissipation applications.
I hope this helps explain the phenomenon you're observing. If you can share more details about your specific application—such as the type of grease you're using, the exact temperature range, and the application—I'd be happy to provide more targeted guidance.
Best regards,
06/28/2026 7:41 AM
Why is the reply from ?Isabella deemed off-topic? It seems to respond quite specifically to the question.
Re: Electrical Conduction of Grease at Low Temperatures
06/05/2012 10:03 AM
The grease you are using, just like other components, has to be suitable for the application...
http://www.2spi.com/catalog/vac/silver-filled-grease-techdata.html
06/05/2012 10:37 AM
Use silicone grease.
06/28/2026 7:53 AM
This article suggests silicone greases may not be suitable for low voltage, long-term, connections which are not regularly remade.
https://support.newgatesimms.com/not-recommended-silicone-grease-use-on-electrical-connectors/
06/21/2026 2:07 PM
Most greases are electrical insulators, and at low temperatures they become thicker, which can increase contact resistance and reduce electrical performance. For electrical applications, low-temperature conductive greases should be selected to ensure reliable operation. VSS POWER ENGINEERING SERVICES LTD. emphasizes proper material selection to maintain equipment reliability in harsh environments.
?Isabella (1); CHRIS_K (2); lyn (1); Mikerho (1); SolarEagle (1); VSS POWER (1)
