Previous in Forum: 60 Hz VFD on 50 Hz Service   Next in Forum: Generators 200kW No Voltage
15 comments
Motor Insulation Resistance Testing
06/05/2012 2:50 PM
After how much time the insulation resistance of a motor should be checked when not in operation? (I am referring to a motor that is put in service and not to a motor that is in storage. The motor may be not in operation because some other standby motor has been taken in service for example.) The corresponding standard should be stated.
Re: Motor Insulation Resistance Testing
06/05/2012 3:41 PM
Depends on the standard to which the motor was built. Do you know what that was?
What DO you know?
06/05/2012 4:08 PM
IEC motors
06/05/2012 4:13 PM
Probably
IEC 60034-18-21
06/05/2012 4:35 PM
i do not have a copy of that .so you can please tell me what is in this code regarding my question.
06/05/2012 7:36 PM
I don't have a copy, either. You should buy one, or ask the motor manufacturer for this information. I don't deal with electric motors any more.
If the motor has always been operated within the specified parameters, then the insulation life should not be a concern until the motor has been in operation for however many hours are specified for its particular insulation class. You can find the class on the nameplate, then maybe you can search for the information yourself, or call the manufacturer.
Good Answers: 181
06/05/2012 8:39 PM
Be realistic lyn, coolyaar buy a publication and read it?
coolyaar if you really need this information you're company would have no problem buying it for you and the company in general.
06/05/2012 11:34 PM
Its a simple test, why not just test it anyway? Is there some limiting factor such as cost, minimal resources, remote location, etc etc. Or, is this for a maintenance plan or something similar?
Fish dont know they're underwater.......think.
Good Answers: 117
06/06/2012 3:13 AM
The only reason you should test a motor is if....
1. it has tripped on overload
2. it has blown a fuse
3. been immersed in water
4. subjected to extreme heat
Please feel free to add to this list.....
As for testing a motor "in service".... I see no benefit, and continual testing with a "insulation tester" has been proven to damage the winding insulation.
I have seen motors (and I'm sure others have too) that have been tested, and then fail after 30 seconds, 30 minutes, 30 hours etc.... so if it's gonna blow.... it's gonna blow, and it don't matter what test you do to it!!
Good Answers: 67
06/06/2012 5:06 AM
It depend on so many factors like- HT or LT motor, insulation class, indoor or outdoor installation, protection type, ambient temp & RH etc.
As of I know, there is no specific standard for it. The reason we need to check is the ingress of moisture & dust along with air inside the winding space and affecting insulation resistance. In rainy season or hot & humid atmosphere it need to be checked more frequently compared to dry and winter weather. So it may range from 10 days to 45 days.
Now a days you can get motors (generally above 15 kW) along with built-in heaters with auto start and shut-off facilities based on timer or temp to protect the insulation resistance. In such motors there is no need to check it.
06/06/2012 7:28 AM
its your choice.
What's your ISO norms stats?
You can test every 6 months / 12 months / 24 months. depend upon the application /environment in which motor is running / any tripping faced etc...
If the motor is placed in Hazardous area, definitely, every time after a gap you start motor, one should check as a safety.
otherwise, no need.
Exploring the Science of Electricity
Good Answers: 117
06/06/2012 7:48 AM
Harry.. the LAST thing you want to do in a hazardous area is introduce a spark potential, as you would/could get from using a 1000v "insulation tester"
Safety first!!
06/06/2012 9:25 AM
Yes,, he needs a Baker Surge tester... that will limit the test to just once..
It's not Rocket Science
06/06/2012 9:03 AM
Mr. Brich,
5. In case of burn smell
6. Observe smoke
Good Answers: 117
06/06/2012 5:11 PM
if I found my motor with either one, then I would not waste my time testing!
New motor!!
06/06/2012 3:46 PM
At the time when you want to run it.
Register to Reply 15 comments
arifkunnath (1); brich (3); claritysable (1); coolyaar (2); harry potter (1); lyn (3); Max Ngwira (1); pritam (1); Rockyscience (1); TonyS (1)
