Previous in Forum: Motor Insulation Resistance Testing   Next in Forum: Other Problem Generators 200kW Voltage Unstable
Generators 200kW No Voltage
06/06/2012 1:01 AM
hello,
I have stranges things on port diesel generator on a high speed ferry I am working on:
- engine is caterpillar C9
- alternator (200kW) is leroy somer LSA M 46.2L9 C6/4, 400V, 3P, 50Hz, 1500rpm, regul R448 AREP
Nearly each time we start engine, speed is OK but we get no voltage out of the generator, we stop engine and start again and every things is OK. One time, I tried to keep engine running and voltage came after 40seconds running. Sometimes We have to start and stop engine several times before getting voltage.
During normal operation, voltage is stable and diesel generator is working good.
We checked connections and took mesurements of resistance of the windings but found nothing strange.
rem: This Diesel Genetrator is started every 12hours.
rem: The diodes bridges and windings are quite dirty (dust)
We saw 3 technicians about this problem but they have no ideas...
do you have any ideas? do you know any test we can do to find the problem?
thanks again
Pathfinder Tags: generators
Re: generators 200kW no voltage
06/06/2012 1:07 AM
Just from the hip sounds like the exciter circuit is intermittent ......
06/06/2012 6:33 AM
already replied to haulguepa.
problem seems to be with excitor winding insuation. Getting leaky after some fix 100 Hrs. of operation. Cold condition, working OK, Hot running conditions, operation fails.
Exploring the Science of Electricity
Re: Generators 200kW No Voltage
06/06/2012 4:38 PM
sorry harry,
the problem is not same, it is not the same DG, this one is port side.
The problem of no voltage happen even cold start.
thanks again for your help
pa
06/07/2012 9:46 PM
no more ideas?
06/11/2012 3:50 AM
What was the outcome of the telephone call to the original equipment manufacturer's technical helpline?
08/17/2012 9:56 PM
still the same problem,
no ideas?
pa
08/03/2013 4:17 PM
hello,
we finaly changed the AVR and it is ok now.
thanks
pa
Register to Reply 7 comments
harry potter (1); hauguelpa (4); PWSlack (1); SolarEagle (1)
