Previous in Forum: Volvo S60 Dashboard   Next in Forum: Grit Blasting
Diesel Engine Fill Gasiline
06/13/2012 1:19 AM
i have a friend he fill wrong fuel on the pick-up deisel engine he put gasoline and the question is we want to reuse the gasoline! and what is to mix on the gasoline to make a deisel. to run the deisel engine ?? and howmuch the quantitie of mix ing one gallon of gasoline ??
thank you hope you can help us !!!
i want ot helf piple need assistance and to share my knowleged in technical
Re: diesel engine fill gasiline
06/13/2012 1:48 AM
06/13/2012 4:28 AM
First get rid of your friends drivers license being he is obviously to dumb to be on the road since he cant tell the difference between the gasoline or diesel fuel dispensers at the fuel station.
Second drain the tank and don't bother trying to reuse it for anything. Consider the wasted fuel time and money the price paid for learning how to pay attention the hard way.
In stock form the gasoline will ruin your diesel injection pump and possibly the whole diesel engine.
As far as running a diesel engine on a non conventional mix of other combustible liquids a 80/20 used oil and E85 mixture that has been well filtered will run in a diesel with good results!
06/15/2012 7:56 AM
GA
The cost of repairing the engine if this fuel is used will exceed its value many times. It does not matter if it is burnt in a petrol or a diesel engine, same result....
Register to Reply 3 comments
Andy Germany (1); SolarEagle (1); tcmtech (1)
