Previous in Forum: Diesel Engine Fill Gasiline   Next in Forum: Gleason vs Cyclo-Palloid Spiral Bevel Gears
Grit Blasting
06/14/2012 2:50 AM
After grit-blasting how to remove any fine powder residue from aluminium inserts
Re: grit blasting
06/14/2012 3:29 AM
Air blasting.
Engineering Fields - Manufacturing Engineering - Hobbies - Musician - Engineering Fields - Mechanical Engineering - Popular Science - Weaponology -
Good Answers: 39
Re: Grit Blasting
06/14/2012 10:24 PM
That's right. Get out the good old air nozzle.
Re: Grit Blasting
06/14/2012 10:53 PM
Check what material you are using to grit blast with - some are "lower dust" than others. As the others say, airblow after blasting helps, but if you get the media correct (and if recycling, clean between cycles) it will help.
Re: Grit Blasting
06/22/2012 11:35 PM
Depending on the shape of your part and your circumstances, running your inserts through an parts washer with a filter may also help. Are these parts held to a cleanliness spec.? We used to go the air-blow route and after a time, you have a gritty mess everywhere.
Every Time a man buys a Glock, God saves a Puppy
Register to Reply 4 comments
Bevelgearpro (1); Kiwi Bill (1); Out of Box Experience (1); PWSlack (1)
