Previous in Forum: Reidar Finsrud's Perpetual Motion Machine   Next in Forum: New to Us Tsugami BW-07
12 comments
Good Answers: 39
Repairing a Storz & Bickel Volcano Vaporizer Heating Unit.
06/20/2012 12:25 AM
Did a search. Found no parts, only a sole repair place in Oakland that only accepts mail-in orders and doesn't answer their phone or respond to email. (I'm ten minutes away). Checked the thermostat contacts, zero ohms. Have full voltage across heater element, which is enclosed in a screen. Can't figure out how to disassemble the heater to check the physical continuity of the heating wire. The air pump works fine.
Align culture with nature...
Pathfinder Tags: Vaporizer Volcano Vaporizer
Re: Repairing a Storz & Bickel Volcano Vaporizer heating unit.
06/20/2012 1:27 AM
If the heater element terminals are accessible, measure the ohms. ∞ = open circuit = broken element.
Good Answers: 102
06/20/2012 10:59 PM
If OP can access the terminals to measure volts across the element then measuring the element's continuity should not be a problem.
Whether or not the voltage measured is correct for the heater or not is another matter...
Good Answers: 39
06/21/2012 2:37 AM
I see I failed to include the open measurement across the element. My main interest is finding someone who has taken apart the heater element. It's kind of inscrutable.
06/20/2012 6:59 AM
They don't offer heating unit parts, they only repair in-house....My advice is to buy another one and send yours in to be repaired so you'll have a back-up....
Good Answers: 39
06/21/2012 2:44 AM
The units now cost close to six hundred dollars. Haven't got it. Used ones are available on Craigslist San Francisco for half that. They have a very long life, apparently.
Good Answers: 102
Re: Repairing a Storz & Bickel Volcano Vaporizer Heating Unit.
06/20/2012 11:03 PM
A halogen lamp makes a fine vaporiser element and its already in a glass envelope.
If your element is rooted then you could attempt a DIY retrofit.
Happy Days.
Good Answers: 39
06/21/2012 2:47 AM
That's a Very Good Idea. The unit is rated at 120 watts, of which twenty watts is air pump, I suspect, and a hundred watts is heater. When I get the heater ass'y back, I'll see what's possible.
Good Answers: 39
06/21/2012 2:42 AM
Went to the repair store on 60th and San Pablo, just north of Powell exit on W80. Negotiated a little bit, going to have them fix it, and return the failed part to me. It's a 9/2004 unit, and has been used 4 times a day since then for dispensing medical vapors. That's 4x365x8=11,680 thermal cycles, about fifteen minutes apiece. Not bad for a nichrome wire heater, although I haven't seen it yet. I'll keep ya posted.
08/03/2013 7:56 AM
Dear ormondotvos, thank You for posting this thread!
Could You please inform how the story ends?
I´m facing similar problem with my Volcano now and the only recovery option here in EU is to send to producer in Germany, it seems.
10/12/2014 4:01 AM
K check it out! I have successfully opened the volcano and exposed the heating element. Having done that I am now having difficulty finding a replacement.
10/14/2014 8:08 AM
Please inform when You find one, dear nyantho.
In the meantime I´ve found alternative that is cheaper, but still I plan to send my broken piece to DE for repair.
Good Answers: 102
06/21/2012 3:13 AM
Those vaporisers are ridiculously expensive IMO.
Pretty darn simple things.
Register to Reply 12 comments
nyantho (1); ormondotvos (4); sedivec (2); SolarEagle (1); Tornado (1); Wal (3)
