Previous in Forum: Calcium Oxide   Next in Forum: Contamination In SS 316L Pipe/ Jacket
17 comments
Material Selection for the Gas (NH3+H2O+Co2)
06/24/2012 7:15 AM
Hi guys
We want to select a sufficient material for exchanger which the gas (NH3+H2O+Co2) with pH=13.7 and 900c is passed.
We have 2 selection: 1. SS316, 2. Carbon steel with PVDF coating
Which one is better?
Please help me with strong reason.
Thank you so much
Re: material selection for the gas (NH3+H2O+Co2)
06/24/2012 9:14 AM
It depends on what is the other fluid as well, Boss. It's no good going for carbon steel if the other fluid is nitric acid, is it?
Good moaning!
Good Answers: 61
Re: Material Selection for the Gas (NH3+H2O+Co2)
06/24/2012 5:54 PM
All too vague to give an informed answer.
06/24/2012 9:02 PM
Is the other fluid the 30% brine mentioned in another thread?
What are the percentages of NH3, H2O, and CO2?
What is the purpose or process behind this unusual combination?
PVDF is probably not very high in thermal conductivity, thus doubtful for HX service.
06/25/2012 12:21 AM
Percentages of NH3, H2O, and CO2 is 41, 38, 21 respectively.
There isn't any other fluid in this part!
We want to use PVDF for the shell of exchanger, not the tubes. So, the low thermal conductivity is a useful property.
I know the reason of corrosion resistance of SS316 is formation of Cr2O3 and Cr2O3 layer formes in oxidizing media. But our media isn't oxidizing. Does Cr2O3 layer forme in this situation?
Thank you
06/25/2012 3:14 AM
<...There isn't any other fluid in this part!...>
How is an exchanger supposed to work with only one fluid?
06/25/2012 4:22 AM
Excuse me, I didn't understand his opinion.
Other fluid is a carbonated lisuid.
06/25/2012 4:37 AM
There is unlikely to be any corrosion issues with either material.
BTW: the measurement pH applies only to aqueous solutions and is meaningless in the context of gases.
06/25/2012 5:08 AM
Correction: it depends upon the carbonated liquid. If this is a misprint for "hydrocarbon liquid", then the above #8↑ stands. If the carbonated liquid has a low pH as a result of its being aqueous CO2 then more information about it is needed to resolve the materials selection issue.
A bunch of facts would go down a bundle on this thread.
06/25/2012 12:03 AM
Any coating on steel needs preparation !! (especially PVDF)
As so the Stainless Steel will be cost beneficient -think about coating repairs later....
Suggested to do passivation on the stainless steel too.
06/25/2012 9:17 AM
Definitively SSS316L (better with "L" - Low Carbon, if the joints will be welded) over any further alternatives involving CS. Have special attention on the butt weldfng of the pipes (you don´t mention the pressure so I guess you have to joint them with a butt-welded procedure). They must made with a N2 purge to avoid the forming of chormiung carbides that eventually will form focus of corrosion. A little more expansive as an investment but dramatically better in a cost-benefit scheme.
Good Answers: 34
06/26/2012 10:45 AM
What about DUPLEX (With N2 purge)?
06/26/2012 11:11 AM
What is DUPLEX?
This SS316L piping buttwelding process by TIG with Argon but the inert media inside the pipes (a couple of plugs in the ends and so on) with N2.
Regarding to Argon or Nitrogen for purging, this one is often used for purging stainless steel pipe and tubing systems. It is much less expensive than argon and it keeps the oxygen away from the root of the weld. Besides N2 is a diatomic molecule under "normal" conditions, and as this N2 molecule it is basically inert. But if someone want to use for the TIG process, N2 breaks down to single atoms in the welding arc and becomes very reactive with molten and hot steel, so Nitrogen cannot be used as an arc shielding gas. N2 can be used as a purge gas since it is not exposed to the welding arc.
Don´t think twice if you want a long life span!
06/26/2012 11:58 PM
Yes you'r right!
I'll think about it.
Thank you
06/27/2012 9:07 AM
Yes you'r right!
Yes, you're right!
Good Answers: 34
06/27/2012 11:49 AM
Abstract
Duplex stainless steels have an extensive,
successful, track record in a
multitude of corrosive and erosive
environments up to 315°C (600°F),
while providing high immunity to
stress corrosion cracking (SCC).
Althoughduplex stainless steels are,
in many cases, superior in corrosion
resistance and strength compared to
304 and 316 austentic stainless
steels, many fabricators continue to
have difficulties creating welding
procedures that yield repeatable
weldments with optimum properties.
This paper offers practical welding
guidelines to new fabricators
who want to archieve high quality,
robust stainless steel weldments
supplementing API 938-C,. "Use of
Duplex Steels in Oil Refining
Industry". Discussion
includes the importance
of balancing ferrite
to austenite, reducing formation
of deleterious intermetallic and
nonmetallic phases, measuring ferrite
contents, and suggested welding
parameters.
06/27/2012 4:47 PM
OK, DUPLEX is better, more %Cr, they have a two-phase microstructure consisting of grains of ferritic and austenitic stainless steel in almost the same quantity. It makes a very high corrosion resistent. No doubt, is a superior choosing, but I think 316L for this aplication is enough. This is in the designer hands.
Good Answers: 34
06/28/2012 2:07 AM
Yes, and more expensive.
Register to Reply 17 comments
Anonymous Poster (1); Crabtree (1); energyconversion (1); georgeh (3); Jacob Klepatch (1); PWSlack (3); Tornado (1); Whitephone (3); zanba (3)
