Previous in Forum: Single Direction Tilting Pad Thrust Bearing (Mitchel Type)   Next in Forum: Heat Exchanger Design
Heat Dissipation
06/24/2012 11:13 PM
In this age of software making things too easy, sometimes you have to resort to old fashioned thinking it thru. I forgot a simple formula to find heat dissipation on the surface area of a hydraulic reservoir. I sure could use a little help!!
Re: Heat dissipation
06/24/2012 11:37 PM
Something like this?
0.001 X Surface Area X Difference between oil and air temperature
If the oil temperature is 140 degrees, and the air temperature is 75 degrees, how much heat will a reservoir with 20 square feet of surface area dissipate?
Surface Area = 20 square feet
Temperature Difference = 140 degrees - 75 degrees = 65 degrees
0.001 X Surface Area X Temperature Difference = 0.001 X 20 X 65 = 1.3 horsepower
Note: 1 HP = 2,544 BTU per Hour
06/24/2012 11:47 PM
SolarEagle,
Thank you for your assistance.
Good Answers: 19
06/25/2012 3:56 AM
Btu/hr divided by Latent Heat of Steam = lbs/hr.
06/25/2012 4:19 AM
Ain't that the truth... Soetime the software just gets you to the wrong answer quicker.
Now where's my pencil and squared pad?
Good Answers: 19
06/25/2012 4:13 PM
Hey Del, long time no see you purrrrrrrrrrrrrring.
Good Answers: 54
Re: Heat Dissipation
06/25/2012 10:36 PM
I think SolarEagle is uncharacteristically wrong in his explanation.
How much heat will be dissipated is quite complex but if we ignore the radiated component, assume the hydraulic oil is at a constant temperature and there is forced air flow over the surface, then the formula comes down to:
Q = ΔT/R, where R is the thermal resistance of the wall.
and R = x/Ak, where x = thickness, A = Area of surface and k = thermal conductivity.
If there's something you don't understand...Then a wizard did it. As heard on "The Simpsons".
Good Answers: 183
06/29/2012 12:30 PM
I think that your correction is WRONG:
there are in the reservoir 3 heat exchange zones:
- oil to wall by convection
- through wall by conduction
- wall to air by convection again.
Thermal resistance of the first 2 are quite low in comparison with the last which also detriorates versus time due to dirt deposits on external wall surface.
Due to low temperature differences radiation which proportional to T^4 is very low in comparison with convection which is proportional to T^1.
If the wall is not in an induced air flow then only free convection occurs with coefficients around 8 to 15 W/m²°K. Now if the wall is steel with a thicknes of let say 6 mm and a condcutivity of 50 W/°Km you can compare the thermal resistances:
wall conduction t/(A*λ) = 6e-3/50=1.2e-4 °K/W and the one for convection 1/(α*A)= 0.067 to 0.125 °k/W. You understand that the difference is such that it can be considered that only outside convection is the criterion.
Register to Reply 7 comments
curious123 (1); ducon (2); ffej (1); nick name (1); SolarEagle (1); user-deleted-1105 (1)
