Previous in Forum: Class of Neutral CT   Next in Forum: Merlin Gerin c800n MCCB Dial Settings
Conventional VFD
06/26/2012 6:34 AM
hi all,
just wanna ask if I can use a non servo VFD to a servo motor? If I can do so what parameters do I have to change?
Pathfinder Tags: Servo motor
Re: conventional VFD
06/26/2012 6:45 AM
Why would one want to?
Good Answers: 73
Re: Conventional VFD
06/26/2012 1:00 PM
Most non servo VFD's are designed to run a three phase induction motor. Among the parameter differences will be the number of poles and the peak current that the VFD could withstand.
The VFD will want to drive the motor with a relatively constant voltage but use current to generate torque. A servo motor generally swings the voltage all over the place and the current follows. Consequently, you will not get very good performance from the VFD as a drive device.
Not knowing what brand of VFD or motor you are talking about, I can tell you that one thing your VFD probably does not have is any kind of input for overheating warning. Consequently, by experimenting you may cause permanent damage to either or both devices if they are too far apart in operating ranges.
By the time you finished experimenting you might not be impressed by the performance of either device. But using a good servo drive should be much more interesting because they can start and stop very rapidly. Can't do that with a VFD and an induction motor very well.
06/29/2012 5:35 AM
Thank you sir......
Good Answers: 804
06/26/2012 6:44 PM
Where are you going to connect the resolver or encoder from the servo?
Register to Reply 4 comments
engr. (1); JRaef (1); NotUrOrdinaryJoe (1); PWSlack (1)
