Previous in Forum: Fuel Treatment for Diesel Engines   Next in Forum: sa 516 gr 70 material
HVAC Duct Sound Reduction Using Fibre Glass Insulation Materials
07/06/2012 6:50 AM
Hi, Can any body send me how to reduce the sound levels in HVAC ducts? Is there any specification which gives, what is the Thickness to be used for reducing each 10 DB of sound level in HVAC ducts.
Re: HVAC Duct sound reduction using Fibre glass insulation materials
07/06/2012 7:41 AM
One of the options is to reduce the velocity in each duct.
Re: HVAC Duct Sound Reduction Using Fibre Glass Insulation Materials
07/06/2012 9:41 AM
Sound in the duct is most likely attributable to poor design...Insulation of metal duct is usually done by gluing 1/2" fiberglass to interior before fabrication...Your best bet, as mentioned above, is to lower air velocity, or possibly install flex duct section(expansion joint) at supply to minimize vibration....
http://www.indiamart.com/unijoint-fabrications/expansion-joints.html
http://www.soundproofingamerica.com/soundproofing-products.asp
07/06/2012 11:32 PM
Something that - may or may not - work would be to apply stick on sound absorbing panels to the outside of the duct. But this would be very easy. An asphalt based product gluing over full area would have best chance - not a rock or mineral wool panel with mounting tabs.
May be available from an automotive supplier.
Check if duct is rigid, or resonating / vibrating.
Floss or die!
07/08/2012 8:44 PM
SP, is the duct resonating or vibrating?
Or is it just air noise from the air movement?
There may be a cheaper solution.
Floss or die!
07/07/2012 12:03 AM
Usually sound attenuators are provided at the out let of AHU. As already mentioned reduce the velocity of air . this will increase the duct size and cost. You can use good insulation materials of 75 to 100 mm thick with chicken wire mesh arranged in wood pattern as sound absorbing method. For more details you can refer ASHRAE Handbook or any reputed HVAC consultant.
07/08/2012 8:30 PM
My A/C ducts have urethane foam adhered to them on the inside, but inside or outside the result is a quiet airflow - no drumming/resonance. If I remember correctly it is about 10 to 15mm thick.
Register to Reply 6 comments
mrswamy (1); PWSlack (1); SolarEagle (1); Stuart21 (2); WAWAUS (1)
