Previous in Forum: How to Assemble Pinion & Shaft of the Girth Gear of the MND ?   Next in Forum: Coal Pulverized Steam Boiler
New Diesel Generator Testing
07/12/2012 11:52 AM
, we have brand new 350 kva Doosan diesel generator during testing we observed following pl advice remedy & guidance ,we already assembled 67 units,but this situation we are facing first time 1, on 80% load turbo going red hot 2. 100% load situation very worst 3,black smoke problem also exist 4, just for testing for 5 mints generator can't run on 110% load, pls guide us & advice if possible pl give your mob no if possible thanks & best Regds A.ghaffar Pidha
Re: New diesel generator testing
07/12/2012 11:57 AM
Call the manufacturer! Call the manufacturer!
Nobody here will be able help trouble shoot their (brand new) equipment like their own technical people.
The free advice you get here won't solve the problem. Yes, you may have to pay someone to come and fix your problems, but Call the manufacturer! Call the manufacturer!
Re: New Diesel Generator Testing
07/12/2012 1:36 PM
Dear Mr. AGPidha,
This matter/problem is relating to the COMBUSTION aspect of the engine. It is an indication that unburnt fuel escapes with exhaust gas and hence the burning is contiuing in the exhaust gas pipe. The possible reason is the atomisation of diesel is very poor. If atomisation is very poor, the burning will continue in the exhaust pipe. Check the fuel injector pressure and nozzle.
Alternatively the air supplied for combustion is not sufficient and burning is poor causing black smoke. Check for blockage in the air supply system.
If the diesel particle is high in size, the contat air over the fuel droplet cannot react with full particle of the diesel and combustion wll NOT be completed , contiue to burn in the exhaust pipe, resulting in high temperature. This is highly risky.
DHAYANANDHAN.S
07/13/2012 3:22 AM
This is the tool needed to fix it.
Register to Reply 3 comments
Anonymous Poster (1); dhayanandhan (1); lyn (1)
